JN5168 bAHI_UartEnable code example?
shauntaylor
I've noticed that bAHI_UartEnable is the new alternative to vAHI_UartEnable but cannot find any example code using it. Can anyone point me in the right direction please?
finstonian
you can find an example that uses bAHI_UartEnable in the following application note:
http://cache.nxp.com/documents/application_note/JN-AN-1223.zip
Check out the file uart.c in the Source\Common folder.
ygensas
This kind of example could be very usefull for me. Did you find one ?
Other question: I'm not able to download template (JN-AN-1158) for JN-5168. Do you have it ?
