Hello Community
In page 11 of AN4467(i.MX 6 Series DDR Calibration) , there is description as bellow.
ZQ calibration is a process that tunes the DRAM and MMDC I/O Pad output drivers (drive strength) and
ODT values across changes in process, voltage, and temperature.
After ZQ calibration, we can read ZQ_HW_PD_RES and ZQ_HW_PU_RES fields of the MPZQHWCTRL register.
How does ZQ_HW_PD_RES and ZQ_HW_PU_RES relate to DSE field of IOMUX control register and DDR ODT?
That is how should I set DSE filed and MMDC_MPODTCTRL register according to the ZQ result.
Thank you!
ZongbiaoLiao
Hi ZongbiaoLiao
unfortunately this is misprint, calibration process
does not tweak and relate to DSE field of IOMUX control register.
Hi, igor
Thank you for you reply!
How to use ZQ_HW_PD_RES and ZQ_HW_PU_RES after ZQ calibration finished.
Thank you!
Hi ZongbiaoLiao
please check sect.44.11.2.1.1 ZQ automatic Pull-up calibration,
44.11.2.1.2 ZQ automatic Pull-down calibration
i.MX6DQ Reference Manual
http://cache.freescale.com/files/32bit/doc/ref_manual/IMX6DQRM.pdf
Hi igor
Please help me!
Thanks.
Hi ZongbiaoLiao
please check sect.44.12.32 MMDC PHY ZQ SW control register (MMDCx_MPZQSWCTRL) :
MMDCx_MPZQSWCTRL[USE_ZQ_SW_VAL ] - this bit selects whether ZQ SW value or ZQ
HW value will be driven to the I/O pads resistor controls.
Hi Igor
ZQ automatic Pull-up calibration and ZQ automatic Pull-down calibration are just the two parts of ZQ calibration.
After ZQ calibration finished, who should refer to the results(ZQ_HW_PD_RES and ZQ_HW_PU_RES)?
Thank you!
