LPC3250
LPC3250
K_S_Lin
Hi supporters,
      we have a customer who is designing LPC3250 with samsung NAND flash whose part number is K9F4G08F
but failed to access it, I read its datasheet, K9F4G08F is a SLC 4Gbit NAND flash but LPC3250 datasheet says it only support MLC NAND flash with up to 2Gbit flash size.
my question is can LPC3250 support this SLC 4Gbit NAND flash?
jamesbone
Hello K.S.,
Yes the LPC3250  supports  both  MLC and SLC Nand Flash,   even the board LPC3250 Developer's Kit , contains an SLC Nand flash memory, here is a link:
LPC3250 Developer's Kit | Embedded Artists AB
Jaime
K_S_Lin
thanks James
     the ref.design of EA, it uses K9F1G08U0A-P which is a 1Gbit NAND flash, not 4Gbit flash.
would you please to suggest a 4Gbit NAND flash to me? thanks in advance.
