Hello and welcome to the fora, Jocelyn.
This seems quite odd.
If you have not loaded the SCID in a while you should be able to load two successive bytes without waiting.
This is because of the buffer on the main shift register.
Try loading two bytes of data in the first instance and see what you get.
Just do to concecutive byte loads to SCID.
Of course this presumes you have setup the baud clock and enabled Tx!
