I'm using the MPC5777M with its evaluation board and MPC5777M-512DS Adapter.
I would like to use the external memory on MPC5777M-512DS Adapter which is an SRAM (NXP information on web site) but I have some difficulties with the configuration.
When I watch the EBI memory zone with Lauterbach, I only see 0xFFFFFFFF. It seems to be a FLASH memory.
Where can I find documentation about the MPC5777M-512DS Adapter for the MPC5777M target?
I would like to verify:
If someone have an exemple of EBI configuration for this target, I will appreciate.
David
OK thanks for your answer
MPC5777M-512DS has installed two flash memories thus information provided by web summary is incorrect.
Apparently the only public documentation for this mini-module is schematic you can download here:
http://cache.nxp.com/files/32bit/hardware_tools/schematics/SCH-27853-MPC5777M-512DS.pdf
