MC33816AE
MC33816AE
atick
as part of my project, I'm required to design a peak and hold fuel injector driver, the MC33816AE is the suitable chip i found but I'm not sure what MCU to use, could you guys please help me choose what MCU to use to program this datasheet.
https://drive.google.com/drive/folders/0B0i5hrv_K4yBVkhHTVNxSjZmR0E  for this particular diagram, and i also need help with the diagram components, for example the value of the resistors or what type of diodes to use.
thanks
atick
this driver will be use on direct injector with 65volts and i really really need help urgently please
xiangjun_rong
Hi, Atiq,
As you know that the MC33816 is used in auto application, so i suggest you use auto processor for example MPC56xx/MPC57xx.
Pls refer to the doc:
https://community.nxp.com/docs/DOC-331495
If you still have question, pls post your question to MPC forum.
Hope it can help you
Xiangjun Rong
