Write Flash
Question asked by Gregory Clement on Sep 7, 2016
Latest reply on Sep 23, 2016 by Edward Karpicz
Hello;
I program a microcontroller mc9s08sh4 .
I used the various discussing how to read and write to the flash . I use the example given on the forum:
Unable to write S08 flash in run mode
I manage to save one time a character, but I can not do it after.
Here is my example code :
void main(void)
unsigned char Byte_To_Be_Programmed = 'D';
/* Start by copying the Flash Routine to RAM */
CopyInRAM();
/* Init Flash Clock Divider */
FlashInit();
if (Flash_Program(0xFFB0, Byte_To_Be_Programmed))
/* Error while programming a Byte, write your error handling here */
Byte_To_Be_Programmed = 'B';
EnableInterrupts;
for(;;)
__RESET_WATCHDOG();
The first time , the variable 'D' ( 0x44 ) is stored in memory .
As against the variable 'B' does not register properly ( 0x40 )
Whatever the second variable , it is always 0x40 .
Do you have an idea of the problem?
Thank you for your help. DSL for my English
