MCF51JM128 Bootloader AN3748
lucas_loizaga
Hi!
Over 5 years ago FSL support sent me the source code of the application of PC AN3748.
Currently I need to run this AN using Windows 64 bits.
The package was updated with AN3748 compatible drivers, but these drivers do not work with the original PC application.
Please could someone from NXP or FSL post the updated source code of the PC application?
Thank you very much,
Lucas
dariobalina
Anyone have backuped the zip containig the AN3748 source code?
There are no traces of it on the web, It seems that many of Freescale's old application notes resources have been removed.
Dario
lucas_loizaga
Hello!, anybody here?
vicentegomez
Hi Lucas
Please check the attached file, this is the last version that I have,
I hope this will help you.
Vicente Gomez
