NT3HXXXX Product Lifetime
lukewalker
I'm investigating the possibility of including NFC tags within our products for easy calibration routines. I'm interested in two ICs (NT3H1XXX & NT3H2XXX) that offer dual-access EEPROM via I2C and RF field.
What are the expected project lifecycles of these products? How long could I expect support for these devices? If you were to obsolete the product, would a pin-swappable replacement be available?
Also which reader ICs would be best compatible with each of these products?
Luke Walker
Renishaw PLC
vicentegomez
Both families are active, but if you need more information about these families you need to contact your local NXP distributor.
regards
Vicente Gomez
