Thank you, but it does not provide example how to implement hid device descriptors to use it as a keyboard, joystick or mouse.
You had some examples on that before, but its not on sites anymore.
Is lpc1343 going in to stage were its not supported anymore?
Hi Jakub,
You could use the following Application note as referece, it explains how to use the on-chip USB drivers in the LPC1300 Cortex-M3 based microcontroller to implement a simple USB Human Interface Device (HID):
http://cache.nxp.com/documents/application_note/AN10904.zip
Hope it helps!
Carlos Mendoza
Technical Support Engineer
