Linux:3.14.28
The default EDID is from the device tree.Whether 3.14.28 linux does not support the acquisition of EDID from I2C
it is working fine with nxp official linux releases
i.MX 6 Series Software and Development Tool|NXP
please check if proper HDMI cable used, check that you use "true"
HDMI or just a HDMI - DVI adapter.
"True" HDMI display with special HDMI cable should be used.Best regards
