PCA9559PW data sheet, page
degenerm
Hi, on page #6 bottom row is the cell write cycle stated with 100,00 min. I assume this is a typo and it should be 10000 min. Can you pls. confirm this?
Thank you, best regards Manfred
TomasVaverka
Hi Manfred,
You are right, the datasheet is a bit unclear about this and needs to be updated. However, the minimum number of write cycles is 100,000 (or 100K). This is also shown in the Revision History table on page 10.
Tomas
PS: If this answer helps to solve your question, please mark it as "Correct". Thank you.
