SD Card Logger
SD Card Logger
monstor
I would like to make a SD Card data logger by using S12DP512. Is there any reference design?
Tags (2)
rayhall
Contributor V
Hello Henry
I was working on porting a SD library to the S12XE, that in the past I was using with the Atmel AVR. It uses FAT32.
The project was a CAN Bus logger that saved data to a SD card. I was still testing when I had to change to another project.  I have attached the code. If you make improvements I would like a copy.
Ray.
lama
I am really very sorry but here is not such an application note or reference design created by NXP (FSL).
best regards,
Ladislav
