How to set wifi card on i.mx6 sabresd(YOCTO)?
hanseunglee
Hello everyone.
kernel 3.14.52
i.MX6dl sabresd board
Ubuntu 14.04
YOCTO
I want to set wifi card on my board(i.mx6dl sabresd).
wifi card driver is ath10k(it is device of Atheros)
In my case set like below..
1. menuconfig set.
check [*]
Bus support -> PCI support,
                     Message Signaled Interrupts(MSi...MSI-x)
                     PCI Express port BUS support
                     PCI host controller drivers -> Freescale i.MX6 PCIe controller .
Device  Driver -> Network device support --> Wireless LAN ->
                    Atheros Wireless Cards -> Atheros 802.11ac wireless cards support -> Atheros ath10k PCI support ..done.
2. package set
$build/conf/local.conf
Add text for wifi install like below...
IMAGE_INSTALL_append += " iw wpa-supplicant net-tools ethtool pciutils \
modutils-initscripts i2c-tools wireless-tools kernel-modules"
3. Compile and mount to target board(i.mx6dl sabresd)
4. copy firmware
cp firmware-2.bin_10.1.467.2-1 /lib/firmware/ath10k/QCA988X/hw2.0/firmware-2.bin
  and reboot.
But can not work wifi card.
is it wrong ?
If you have solve .. reply please.
jimmychan
Attached is the Linux 3.14.28 BSP Linux Reference Manual. Please read the Chapter 48 for the AR6003 Wifi driver details.
I think you can try to use Linux 3.14.28 BSP. You can download it here :
i.MX 6 Series Software and Development Tool|NXP
hanseunglee
Hello jummychan.
Thank you for your reply.
But, In my case wifi card is PCIe type.it is different with AR6003.
I want confirm set configuration on YOCTO system for wifi card install.
Thank you.
HAN
