Ethernet code for TWR-K65F180M
yadhukrishnanvm
HI,
 I am trying my own ethernet code for TWR-K65F180M in kinetis design studio.The ethernet code means the same example project in the "rtcs" folder, the example name is "httpsrv". I am beginner to embedded system so please guide how to write the code.
maheshwarreddy
If I don't wants to use the example , I wants to write the standalone code for k66 .
yadhukrishnanvm
Hi Maheshwar,
I don't understand please explain what you need?
maheshwarreddy
hi,
Initially I used k60 processor for the Ethernet communication now I replace k60 with k66, I copied the same code to k66 and changed the header
file, and I changed the mcg_c2 registers "EREFS " bit also it is not working . iam not getting interrupts also , for k60 I used the code warrior generated code and I ported it to the keil  , it works fine . but when I port to  the k66 it is not working  ,iam I don't know how to enable the interrupt in the code warrior , if done Ethernet for k65 send the full Ethernet application .
                                           Thank you
regards
Maheshwarreddy
yadhukrishnanvm
I am sorry I don't know how to attach the files :smileysad:
maheshwarreddy
hi,
      make the original file as zip fine  file and send .
maheshwarreddy
hi,
 I had not got any reply from you, can you send that early iam in need .
yadhukrishnanvm
Give me your email id I will send it
maheshwarreddy
hi,
maheshwarreddy681(@gmail.com),ignore the breses
yadhukrishnanvm
I have send it.
maheshwarreddy
thank you ,
       mail me (maheshwarreddy681@gmail.com)
ivadorazinova
Hi Yadhukrishnan V M,
So, you work with MQX, right?
Please take a look at example codes in KSDK Software Development Kit for Kinetis MCUs|NXP
here you will get the package for TWR-K65F180M
https://kex.nxp.com/en/summary
I hope this helps.
Iva
yadhukrishnanvm
I couldn't find an ethernet example in the ksdk folder.. :smileysad:
ivadorazinova
Please go to
C:\Freescale\KSDK 2.0\SDK_2.0_TWR-K65F180M\boards\twrk65f180m\demo_apps\lwip
These demos (FreeRTOS,BM) are described in README file for each demo
for example C:\Freescale\KSDK 2.0\SDK_2.0_TWR-K65F180M\boards\twrk65f180m\demo_apps\lwip\lwip_httpsrv\freertos\readme.txt
and with MQX you will find it under specific demo
C:\Freescale\KSDK_1.3.0\examples\twrk65f180m\demo_apps\lwip\lwip_tcpecho_demo\tcpecho_rtos\tcpecho_mqx folder
These demos are described at KSDK 1.3 Demo Applications User´s Guide located under C:\Freescale\KSDK_1.3.0\doc
Best Regards
Iva
yadhukrishnanvm
Thank you very much... :smileylaugh:
