Is it possible to get BeeStack5.0.0 sources ? We are working on porting our application from IAR to KDS IDE. In example applications precompiled library (BeeStackZrRsRNPSp2_M4.a) is used which was compiled with IAR compiler. Is it possible to get BeeStackZrRsRNPSp2_M4.a soucres in order to recompile BeeStackZrRsRNPSp2_M4.a library with GCC compiler ?
Regards Grzegorz
Hello Grzegorz, unfortunately those sources are not shared outside of NXP.
