Fabrice TOCCI
PWM with FTM on KW24D512
Discussion created by Fabrice TOCCI on Aug 24, 2016
Latest reply on Aug 26, 2016 by Fabrice TOCCI
I'm building a wireless product on KW242512 IC.
I planned to drive a LED brightness with a PWM signal.
I started with KSDK1.3.0 / examples / twrkw24d512 / driver_examples / ftm
PTD4 configured as FTM0_Ch4 is used to drive LED brightness.
I have changed board.h as follow
/* The Flextimer instance/channel used for board */
#define BOARD_FTM_INSTANCE              0
#define BOARD_FTM_CHANNEL               4
When I run the example code nothing happens on PTD4 where I thought a PWM wave will show up.
What is wrong in my setting?
How do I need to use this example code to get a PWM signal on PTD4 pin.
Attached the project files
Original Attachment has been moved to: board.h.zip
Original Attachment has been moved to: main.c.zip
Original Attachment has been moved to: pin_mux.c.zip
