Interrupt configuration problem with MXT224E in imx6DL android kitkat
Question asked by VIVEK TOL on Aug 22, 2016
Latest reply on Aug 31, 2016 by VIVEK TOL
            We are interfacing Atmel MXT224E touchscreen with imx6DL Processor in Android Kitkat 4.4.2.
We have connected it to I2C-2 and interrupt pin is used in GPIO_1_8.
We are getting acknowledge from Touchscreen with Family ID, Variant ID and version correctly.
But some problem is with interrupt. When we touch the screen interrupt number is not incremented after checking using
cat /proc/interrupts command but if manually short it to Ground then it will increment the number.
For this problem any configuration setting we have to do in kernel setting?
