Pre-build action with CodeWarrior 5.1 for HCS12(X)
dreas
Is it possible to add a pre-build action when compiling with CodeWarrior 5.1 for HCS12(X)?
I have an external script that generates some of the source code that shall be compiled and I want to have this script executed automatically on every make request. In the target settings I find pre-link and post-link actions, but none for pre-build. How do I accomplish that?
ZhangJennie
Hi Andreas,
You use Classic version CW. Unfortunately we don't have a "pre-compiler tool".
The batchfileRunner can be laucnhed before or after the linker.
We don't have similar tool for compiler.
I recommend you to use the tool in batch file.
By this way you could do exactly what you want before to launch the compiler.
Jennie Zhang
