How to get BSDL for LQFP Package
berniecheah
Can I request for the BSDL file for LPC2368FBD100 with LQFP package?
Welcome to LPCware.com! | www.LPCware.com
The website only provides FPGA Package and I don't need FPGA..
Thanks!
kerryzhou
Hi Bernie,
    After check carefully with our according department, LPC2368FBD100  doesn't have the BSDL file, because LPC2368FBD100  doesn't support the boundary scan.
Wish it helps you!
Jingjing
EngHuiPeng
Hello Kerry,
Customer required BSDL files(Boundary-Scan Description Language) for LPC2368FBD100 and not the ibis model. Could you check whether we have the BSDL file(should be .bdsl).
Appreciate you could find out whether we have this files.
kerryzhou
Hi Audrey, @Bernie Cheah
   Thank you very much for your remind.
  It's really my fault, I was looking in wrong from the lpcware website, it is the IBIS model not BSDL file, sorry for the inconvenience I bring you.
  Now, I already check it with our according department, we still don't have the LPC2368FBD100 BSDL file, just have the ibis file.
Jingjing
kerryzhou
Hi Bernie,
Wish it helps you!
Jingjing
berniecheah
Hi Kerry,
Thanks!
Thanks & Regards,
Bernie Cheah YQ
(Field Application Engineer)
WPG Malaysia Sdn. Bhd.
• Office : (04) 642 9500 ext: 11670
• Mobile : (016) 451 2052
6 Fax : (04) 642 3499
•Email : bernie.cheah@sa.wpgholdings.com<mailto:siewchoo.siu@sa.wpgholdings.com>
kerryzhou
Hi Bernie,
   If the post is answered your question, please click the Correct Answer button to mark it as solved. Thank you!
Kerry
