Where could I find full DS of NXQ1TXH5.
I'm designing wpc1.2 enabled battery pack. but I don't wanna communicate with NXQ1TXH5 through LED pins.
I'm looking forward I can talk to the ic via I2C.
it's urgent. please let me know..
Thank you.
B.
Regards.
Hi Bong,
The NXQ1TXH5 is an easy to use fully integrated chip that can be completely configured by means of external resistors so in general there is no need to have access to the I2C bus to configure the chip.
That being said, attached you can find a document describing how to read out a few status registers in the NXQ1TXH5.
I hope it helps.
Tomas
PS: If my answer helps to solve your question, please mark it as "Correct". Thank you.
