Watchdog disable bit (WDOG_CS1 b7) isn't working on a PA4.
Question asked by Kevin Sargent on Aug 19, 2016
Latest reply on Aug 19, 2016 by Kevin Sargent
I set an infinite loop, just after program start. If a reset happens it saves the SYS_SRS and loops on resetting watchdog until I manually suspend. It shows a watchdog reset occurred ($20) regardless of watchdog disabled bit. I'm I missing something?  I'm next going to set the watchdog clock to external, which doesn't exist, so should never count.
