zongmi tian
IMX51 Load Hive registry ,Can't into CE System sometimes.
Discussion created by zongmi tian on Aug 17, 2016
WINCE6。0增加了HIVE注册表之后。。重启十多次有可能就会出现一次进不去系统的情况。再重启又进去了。去掉HIVE注册表一切正常。。请问这种加了HIVE注册表就黑屏的情况是什么原因?如何解决?
不是硬件的问题。
硬件平台是IMX515 处理器,
希望能指点迷津万分感谢。我QQ39362580
WINCE6. 0 after adding the HIVE registry.. Restart more than and 10 times there may be a time to enter the system does not go to the CE System. Then restart and go in. Get rid of all the normal HIVE registry.. Does this with the HIVE registry on the black screen of what is the reason? How to solve?
Not a hardware problem.
Hardware platform is IMX515 processor,
Thank you very much hope to help.
USBHost : Detach Hub [address(1) / layer(0)]
INFO:OALLogSetZones: dpCurSettings.ulZoneMask: 0x1f
BSP Clock Configuration:
    CKIH        =   22579200 Hz
    PLL1        =  800000000 Hz
    PLL2        =  665000000 Hz
    PLL3        =  216000000 Hz
    LP_APM      =   24000000 Hz
    ARM         =  800000000 Hz
    AXI_A       =  166250000 Hz
    AXI_B       =  133000000 Hz
    EMI_SLOW    =  133000000 Hz
    AHB         =  133000000 Hz
    IPG         =   66500000 Hz
    PERCLK      =    8000000 Hz
    CKIL_SYNC   =      32768 Hz
    DDR         =  200000000 Hz
    ARM_AXI     =  166250000 Hz
    IPU_HSP     =  133000000 Hz
    VPU_AXI     =  166250000 Hz
    GPU         =  166250000 Hz
    GPU2D       =  166250000 Hz
    DEBUG_APB   =  166250000 Hz
    ENFC        =   26600000 Hz
    USBOH3      =   66500000 Hz
    ESDHC1      =   47500000 Hz
    ESDHC2      =   47500000 Hz
    ESDHC3      =   47500000 Hz
    ESDHC4      =   47500000 Hz
    UART        =   24000000 Hz
    SSI1        =    5644800 Hz
    SSI2        =    5644800 Hz
    SSI3        =    5644800 Hz
    SSI_EXT1    =   10285714 Hz
    SSI_EXT2    =   10285714 Hz
    USB_PHY     =   24000000 Hz
    TVE_216_54  =  216000000 Hz
    DI          =   27000000 Hz
    VPU_RCLK    =   24000000 Hz
    SPDIF0      =    1142857 Hz
    SPDIF1      =    1142857 Hz
    SLIMBUS     =   66500000 Hz
    SIM         =   66500000 Hz
    FIRI        =   24000000 Hz
    HSI2C       =   66500000 Hz
    SSI_LP_APM  =   22579200 Hz
    SPDIF_XTAL  =   24000000 Hz
    HSC1        =  216000000 Hz
    HSC2        =  216000000 Hz
    ESC         =   15428571 Hz
    CSI_MCLK1   =   24629629 Hz
    CSI_MCLK2   =   24629629 Hz
    ECSPI       =   66500000 Hz
    LPSR        =          0 Hz
    PGC         =   66500000 Hz
    OSC         =   24000000 Hz
    CKIH_CAMP1  =   22579200 Hz
    CKIH2_CAMP2 =          0 Hz
    CKIH2       =          0 Hz
    FPM         =   33554432 Hz
Microsoft Windows CE Bootloader Common Library Version 1.4 Built Feb  3 2016 00:02:27
INFO: BoardID = 0x0.
+OALPmicInit
CONTROLREG = 0x1f03011
CONFIGREG = 0x1000
+OALPmicWriteMasked
+OALPmicExchange
-OALPmicExchange
+OALPmicExchange
-OALPmicExchange
-OALPmicWriteMasked
+OALPmicWriteMasked
+OALPmicExchange
-OALPmicExchange
+OALPmicExchange
-OALPmicExchange
-OALPmicWriteMasked
+OALPmicWriteMasked
+OALPmicExchange
-OALPmicExchange
+OALPmicExchange
-OALPmicExchange
-OALPmicWriteMasked
+OALPmicWriteMasked
+OALPmicExchange
-OALPmicExchange
+OALPmicExchange
-OALPmicExchange
-OALPmicWriteMasked
+OALPmicWriteMasked
+OALPmicExchange
-OALPmicExchange
+OALPmicExchange
-OALPmicExchange
-OALPmicWriteMasked
+OALPmicWriteMasked
+OALPmicExchange
-OALPmicExchange
+OALPmicExchange
-OALPmicExchange
-OALPmicWriteMasked
+OALPmicWriteMasked
+OALPmicExchange
-OALPmicExchange
+OALPmicExchange
-OALPmicExchange
-OALPmicWriteMasked
+OALPmicWriteMasked
+OALPmicExchange
-OALPmicExchange
+OALPmicExchange
-OALPmicExchange
-OALPmicWriteMasked
+OALPmicWrite
+OALPmicExchange
-OALPmicExchange
-OALPmicWrite
+OALPmicWriteMasked
+OALPmicExchange
-OALPmicExchange
+OALPmicExchange
-OALPmicExchange
-OALPmicWriteMasked
OALPmicInit:  silicon rev = 0x20
+OALPmicWriteMasked
+OALPmicExchange
-OALPmicExchange
+OALPmicExchange
-OALPmicExchange
-OALPmicWriteMasked
+OALPmicWriteMasked
+OALPmicExchange
-OALPmicExchange
+OALPmicExchange
-OALPmicExchange
-OALPmicWriteMasked
+OALPmicWriteMasked
+OALPmicExchange
-OALPmicExchange
+OALPmicExchange
-OALPmicExchange
-OALPmicWriteMasked
+OALPmicWriteMasked
+OALPmicExchange
-OALPmicExchange
+OALPmicExchange
-OALPmicExchange
-OALPmicWriteMasked
+OALPmicRead
+OALPmicExchange
-OALPmicExchange
-OALPmicRead
REV = 0x45d4
+OALPmicRead
+OALPmicExchange
-OALPmicExchange
-OALPmicRead
REG_SET0 = 0x20fd0
+OALPmicRead
+OALPmicExchange
-OALPmicExchange
-OALPmicRead
REG_MOD1 = 0x9
-OALPmicInit
Embo Windows CE Ethernet Bootloader 1.0 for MX51 EVK (Feb 15 2016 23:44:55)
INFO: SBMR = 0xE0600003.
INFO:  Bootloader launched from SD.
PWE_12V_EN EIM_A17 = 0!!!!!!!!!!!.
+ SDMMC_Init
SDHC_IsCardPresent OK.i=9
SetClockRate - Requested Rate: 150000 Hz, Setting clock rate to 148437 Hz
- SetClockRate
+ SDMMC_card_software_reset
- SDMMC_card_software_reset
+ SD_Init
+ SD_VoltageValidation
SDHCWaitEndCmdRespIntr Error Status: 10001
+ SDMMC_card_send_appcmd
- SDMMC_card_send_appcmd
SDMMC_card_send_appcmd() FAILURE!!! PassTime = 0.
- SD_VoltageValidation
+ MMC_Init
+ MMC_VoltageValidation
MMC High Density card
- MMC_VoltageValidation
+ SDMMC_get_cid
- SDMMC_get_cid
+ SDMMC_send_rca
- SDMMC_send_rca
+ SDMMC_get_csd
- SDMMC_get_csd
SetClockRate - Requested Rate: 20000000 Hz, Setting clock rate to 15833333 Hz
- SetClockRate
+ SDMMC_set_data_transfer_mode
- SDMMC_set_data_transfer_mode
+ SDMMC_set_blocklen=0x00000200
- SDMMC_set_blocklen
+ SDMMC_get_ext_csd
+ CheckDataStatus
- CheckDataStatus ESDHC_STATUS_PASS
- SDMMC_get_ext_csd
+ MMC_SetBusWidth
- MMC_SetBusWidth
MMC: Switched to 4 bit mode
- MMC_Init
INFO: Initialized MMC Card SDController.IsMMC = TRUE
- SDMMC_Init
WARNING: OEMPlatformInit: OK to initialize SDHC device.
INFO: Loading boot configuration from SDHC
SDImageCfg.dwSocId != 233 && SDImageCfg.dwSocId != 28.
+ CheckDataStatus
INFO: Successfully loaded boot configuration from SDHC
INFO: OEMPlatformInit: OK.
System ready!
Preparing for download...
Embo Bootloader EbootDisplayInit()-->
Press [ENTER] to launch image stored in SD/MMC or [SPACE] to cancel.
Initiating image launch in 1 seconds.            0 seconds.
Launching flash image  ...
INFO: Using device name: 'MX5130874'
INFO: Reading NK image to SDHC (please wait)...
+ CheckDataStatus
INFO:  dwActualLength = [0x1e907d4]
INFO: Copying NK image to RAM address 0xa0200000
+ CheckDataStatus
+ CheckDataStatus
+ CheckDataStatus
INFO: Read is 1% complete+ CheckDataStatus
INFO: Read is 2% complete+ CheckDataStatus
INFO: Read is 3% complete+ CheckDataStatus
INFO: Read is 4% complete+ CheckDataStatus
+ CheckDataStatus
INFO: Read is 5% complete+ CheckDataStatus
INFO: Read is 6% complete+ CheckDataStatus
INFO: Read is 7% complete+ CheckDataStatus
INFO: Read is 8% complete+ CheckDataStatus
+ CheckDataStatus
INFO: Read is 9% complete+ CheckDataStatus
INFO: Read is 10% complete+ CheckDataStatus
INFO: Read is 11% complete+ CheckDataStatus
INFO: Read is 12% complete+ CheckDataStatus
INFO: Read is 13% complete+ CheckDataStatus
+ CheckDataStatus
INFO: Read is 14% complete+ CheckDataStatus
INFO: Read is 15% complete+ CheckDataStatus
INFO: Read is 16% complete+ CheckDataStatus
INFO: Read is 17% complete+ CheckDataStatus
+ CheckDataStatus
INFO: Read is 18% complete+ CheckDataStatus
INFO: Read is 19% complete+ CheckDataStatus
INFO: Read is 20% complete+ CheckDataStatus
INFO: Read is 21% complete+ CheckDataStatus
INFO: Read is 22% complete+ CheckDataStatus
+ CheckDataStatus
INFO: Read is 23% complete+ CheckDataStatus
INFO: Read is 24% complete+ CheckDataStatus
INFO: Read is 25% complete+ CheckDataStatus
INFO: Read is 26% complete+ CheckDataStatus
+ CheckDataStatus
INFO: Read is 27% complete+ CheckDataStatus
INFO: Read is 28% complete+ CheckDataStatus
INFO: Read is 29% complete+ CheckDataStatus
INFO: Read is 30% complete+ CheckDataStatus
INFO: Read is 31% complete+ CheckDataStatus
+ CheckDataStatus
INFO: Read is 32% complete+ CheckDataStatus
INFO: Read is 33% complete+ CheckDataStatus
INFO: Read is 34% complete+ CheckDataStatus
INFO: Read is 35% complete+ CheckDataStatus
+ CheckDataStatus
INFO: Read is 36% complete+ CheckDataStatus
INFO: Read is 37% complete+ CheckDataStatus
INFO: Read is 38% complete+ CheckDataStatus
INFO: Read is 39% complete+ CheckDataStatus
INFO: Read is 40% complete+ CheckDataStatus
+ CheckDataStatus
INFO: Read is 41% complete+ CheckDataStatus
INFO: Read is 42% complete+ CheckDataStatus
INFO: Read is 43% complete+ CheckDataStatus
INFO: Read is 44% complete+ CheckDataStatus
+ CheckDataStatus
INFO: Read is 45% complete+ CheckDataStatus
INFO: Read is 46% complete+ CheckDataStatus
INFO: Read is 47% complete+ CheckDataStatus
INFO: Read is 48% complete+ CheckDataStatus
INFO: Read is 49% complete+ CheckDataStatus
+ CheckDataStatus
INFO: Read is 50% complete+ CheckDataStatus
INFO: Read is 51% complete+ CheckDataStatus
INFO: Read is 52% complete+ CheckDataStatus
INFO: Read is 53% complete+ CheckDataStatus
+ CheckDataStatus
INFO: Read is 54% complete+ CheckDataStatus
INFO: Read is 55% complete+ CheckDataStatus
INFO: Read is 56% complete+ CheckDataStatus
INFO: Read is 57% complete+ CheckDataStatus
INFO: Read is 58% complete+ CheckDataStatus
+ CheckDataStatus
INFO: Read is 59% complete+ CheckDataStatus
INFO: Read is 60% complete+ CheckDataStatus
INFO: Read is 61% complete+ CheckDataStatus
INFO: Read is 62% complete+ CheckDataStatus
+ CheckDataStatus
INFO: Read is 63% complete+ CheckDataStatus
INFO: Read is 64% complete+ CheckDataStatus
INFO: Read is 65% complete+ CheckDataStatus
INFO: Read is 66% complete+ CheckDataStatus
INFO: Read is 67% complete+ CheckDataStatus
+ CheckDataStatus
INFO: Read is 68% complete+ CheckDataStatus
INFO: Read is 69% complete+ CheckDataStatus
INFO: Read is 70% complete+ CheckDataStatus
INFO: Read is 71% complete+ CheckDataStatus
+ CheckDataStatus
INFO: Read is 72% complete+ CheckDataStatus
INFO: Read is 73% complete+ CheckDataStatus
INFO: Read is 74% complete+ CheckDataStatus
INFO: Read is 75% complete+ CheckDataStatus
INFO: Read is 76% complete+ CheckDataStatus
+ CheckDataStatus
INFO: Read is 77% complete+ CheckDataStatus
INFO: Read is 78% complete+ CheckDataStatus
INFO: Read is 79% complete+ CheckDataStatus
INFO: Read is 80% complete+ CheckDataStatus
+ CheckDataStatus
INFO: Read is 81% complete+ CheckDataStatus
INFO: Read is 82% complete+ CheckDataStatus
INFO: Read is 83% complete+ CheckDataStatus
INFO: Read is 84% complete+ CheckDataStatus
INFO: Read is 85% complete+ CheckDataStatus
+ CheckDataStatus
INFO: Read is 86% complete+ CheckDataStatus
INFO: Read is 87% complete+ CheckDataStatus
INFO: Read is 88% complete+ CheckDataStatus
INFO: Read is 89% complete+ CheckDataStatus
+ CheckDataStatus
INFO: Read is 90% complete+ CheckDataStatus
INFO: Read is 91% complete+ CheckDataStatus
INFO: Read is 92% complete+ CheckDataStatus
INFO: Read is 93% complete+ CheckDataStatus
INFO: Read is 94% complete+ CheckDataStatus
+ CheckDataStatus
INFO: Read is 95% complete+ CheckDataStatus
INFO: Read is 96% complete+ CheckDataStatus
INFO: Read is 97% complete+ CheckDataStatus
INFO: Read is 98% complete+ CheckDataStatus
+ CheckDataStatus
INFO: Read is 99% complete
INFO: Read is 100% complete
INFO: Copy of NK completed successfully
+ SDMMC_get_ext_csd
+ CheckDataStatus
- SDMMC_get_ext_csd
Download successful!  Jumping to image at 0x0 (physical 0x90200000)...
    CKIH        =   22579200 Hz
    PLL1        =  800000000 Hz
    PLL2        =  665000000 Hz
    PLL3        =  216000000 Hz
    ARM         =  800000000 Hz
    AHB         =  133000000 Hz
    IPG         =   66500000 Hz
    PERCLK      =    8000000 Hz
    DDR         =  200000000 Hz
    GPU         =  166250000 Hz
    ENFC        =   26600000 Hz
    UART        =   24000000 Hz
    SSI1        =    5644800 Hz
    SSI2        =    5644800 Hz
    SSI3        =    5644800 Hz
    DI          =   27000000 Hz
    SPDIF0      =    1142857 Hz
    SPDIF1      =    1142857 Hz
    SIM         =   66500000 Hz
    FIRI        =   24000000 Hz
    HSI2C       =   66500000 Hz
    HSC1        =  216000000 Hz
    HSC2        =  216000000 Hz
    ESC         =   15428571 Hz
    ECSPI       =   66500000 Hz
    LPSR        =          0 Hz
    PGC         =   66500000 Hz
    OSC         =   24000000 Hz
    CKIH2_CAMP2 =          0 Hz
    CKIH2       =          0 Hz
    FPM         =   33554432 Hz
Windows CE Kernel for ARM (Thumb Enabled) Built on Mar  8 2013 at 17:05:33
INFO:OALLogSetZones: dpCurSettinOALIoCtlHalInitRTC(2006/1/1 12:0:0.000)
CardBus.DLL DLL_PROCESS_ATTACH
BusEnum::BusEnum (ActivateRegPath=Drivers\Active\01)
ActivateChild: Template reg path is Drivers\BuiltIn\CSPDDK
ActivateChild: Template reg path is Drivers\BuiltIn\ECSPI1
ActivateChild: Template reg path is Drivers\BuiltIn\PMI
ActivateChild: Template reg path is Drivers\BuiltIn\ESDHC1
ActivateChild: Template reg path is Drivers\BuiltIn\SDBusDriver
BusEnum::ActivateChild load device driver at order 0
DeviceFolder::LoadDevice!Loading driver from device key Drivers\BuiltIn\CSPDDK
DeviceFolder::LoadDevice(Drivers\BuiltIn\CSPDDK) last 2 Ticks BusEnum::ActivateChild load device driver at order 1
DeviceFolder::LoadDevice!Loading driver from device key Drivers\BuiltIn\ECSPI1
DeviceFolder::LoadDevice(Drivers\BuiltIn\ECSPI1) last 2 Ticks BusEnum::ActivateChild load device driver at order 2
DeviceFolder::LoadDevice!Loading driver from device key Drivers\BuiltIn\PMI
DeviceFolder::LoadDevice(Drivers\BuiltIn\PMI) last 6 Ticks BusEnum::ActivateChild load device driver at order 21
DeviceFolder::LoadDevice!Loading driver from device key Drivers\BuiltIn\SDBusDriver
SDBusDriver: PROCESS_ATTACH
SDBusDriver: +SDC_Init
SDBusDriver: Bus Driver instance created : 0xD0048AC0 ! -SDC_Init
DeviceFolder::LoadDevice(Drivers\BuiltIn\SDBusDriver) last 10 Ticks BusEnum::ActivateChild load device driver at order 33
DeviceFolder::LoadDevice!Loading driver from device key Drivers\BuiltIn\ESDHC1
SDHCDGetHCFunctions: +Init
SDHCDGetHCFunctions: -Init
SDHC +Init
SDHC Active RegPath: Drivers\Active\06
+CESDHCBase::Init: Active RegPath: Drivers\Active\06
SlotpOptionHandler: Caps = 0x13c, HSS = 0x1
SDHCInitialize++
CESDHCBase::Start: PROCTL set value = 7000021
CESDHCBase32BitADMA2:Create DMA Object for ADMA2
+OALIoctlHalGetCacheInfo(...)
-OALIoctlHalGetCacheInfo(rc = 1)
SDHCInitialize--
-CESDHCBase::Init
SDHC -Init
DeviceFolder::LoadDevice(Drivers\BuiltIn\ESDHC1) last 37 Ticks
stop in here.
