Please tell me about MMA8452Q.3-axis, I set the threshold.To sleep.It will wake up when moved.Can I use such a method?
Hi Roysuke,
Yes, I would recommend you to take a closer look at our AN4074 which explains how to use the Auto-Wake/Sleep feature including example register settings and code.
Attached you can also find my example code written for the FRDM-KL25Z board. The transient function is used to wake up the MMA8451Q and the time-out period is set to 5s.
I hope it helps.
Tomas
PS: If my answer helps to solve your question, please mark it as "Correct". Thank you.
