jiang shao
关于不同版本的mfgtool (About different Mfgtool)
Discussion created by jiang shao on Aug 16, 2016
Latest reply on Aug 26, 2016 by jiang shao
各位尊敬的FAE
我有一块带PMIC的imx6dl sabre-sd,非原装板。
现在发现这样一个问题,
在用M6.0.1_2.1.0专用的制造工具烧写后,再改用Android4.2.2的制造工具烧写,
该开发板无法正常工作。例如:HDMI或LVDS无输出。
串口输出如下:
ERROR: Did not find a cmdline Flattened Device Tree
Could not find a valid device tree
resetting ...
也就是因为找不到devicetree,在反复重启
有哪位知道如何处理吗?
Dear FAE
I have a imx6dl sabre-sd board(with PMIC)(not fsl original).
After burning with M6.0.1_2.1.0 Mfgtool, When I use Android4.2.2 Mfgtool to burn it,
the board can NOT work. For example: no output over HDMI or LVDS
Over serial port can get the following messages:
Resetting...
just because can NOT find devicetree, the board restarts again and again。
Anyone know how to deal with it?
