I have installed Kinetis Design Studio 3 IDE. When I create a new Processor Expert Project, the Processors do not include MKW3x and MKW4x. So I want to know how to add them in KDS? Thank you!
Solved! Go to Solution.
Hello Lingxing,
If you want use the product of KW3x and KW3x , please download and install KSDK1.3,
about the download and install please refer to the doc of "KDS_Users_Guide.pdf"
(it under the KDS install directory : KDS_3.0.0\doc)
You can download it at here :
After install it , restart KDS .
Hope it helps
Alice
Hello Lingxing,
Hope it helps
Alice
Thank you for your help, Alice. I have solved the problem with your method.
Have a good day,
Lingxing
Hi lingxing,
Step 1) go to File >> New >> Processor Expert Project.
Step 2)write project name and click next
Step 3) write processor number you want, select the desired processor configuration and click next
Step 4) select check box for "Processor Expert" and click finish
Idris
Hi Idris, you misunderstand my problem, but thank you all the same.
Have a great day.
lingxing
