IMX6sx JTAG
Question asked by Andreas Werner on Aug 16, 2016
I'm using the IMX6 SOLOX COM BOARD by Embedded Artists.  I used a JLINK Debugger with OpenOCD 0.9.0. The debuging form the Cores working at Uboot like expected, until Linux Kernel boot the JTAG still brocken.
I tried deferent Linux Kernel Versions:
- IMX-Linux: imx_3.14.52_1.1.0_ga: Hangs after caam initialization
  - IMX-Linux: imx_4.1.15_1.0.0_ga: Can't Connect JTAG
  - Linux Mainline: Linux Stable 4.7: Can't Connect JTAG
I start the M4 in U-boot. Program init core and go to Infinitiv loop.
I Attached the OpenOCD Script and the DTC Files for Linux 4.7.
Can somebody help me with this Problem?
OpenOCD output while linux Kernel is booting:
Open On-Chip Debugger 0.9.0 (2016-07-26-22:15)
Licensed under GNU GPL v2
For bug reports, read
  http://openocd.org/doc/doxygen/bugs.html
adapter speed: 1000 kHz
Warn : Transport "jtag" was already selected
Warn : imx6sx.sdma: nonstandard IR value
Warn : imx6sx.sjc: nonstandard IR value
m4_init
Info : J-Link V9 compiled Feb 20 2015 09:20:19
Info : J-Link caps 0xb9ff7bbf
Info : J-Link hw version 93000
Info : J-Link hw type J-Link
Info : J-Link max mem block 70896
Info : J-Link configuration
Info : USB-Address: 0x0
Info : Kickstart power on JTAG-pin 19: 0x0
Info : Vref = 3.214 TCK = 1 TDI = 0 TDO = 0 TMS = 0 SRST = 1 TRST = 1
Info : J-Link JTAG Interface ready
Info : clock speed 1000 kHz
Info : JTAG tap: imx6sx.dapM4 tap/device found: 0x4ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x4)
Info : JTAG tap: imx6sx.dapA9 tap/device found: 0x4ba00477 (mfg: 0x23b, part: 0xba00, ver: 0x4)
Info : TAP imx6sx.sdma does not have IDCODE
Info : JTAG tap: imx6sx.sjc tap/device found: 0x0891c01d (mfg: 0x00e, part: 0x891c, ver: 0x0)
Info : imx6sx.dapM4: hardware has 6 breakpoints, 4 watchpoints
Warn : Invalid ACK 0 in JTAG-DP transaction
Polling target imx6sx.dapM4 failed, trying to reexamine
Examination failed, GDB will be halted. Polling again in 100ms
Examination failed, GDB will be halted. Polling again in 300ms
Examination failed, GDB will be halted. Polling again in 700ms
Examination failed, GDB will be halted. Polling again in 1500ms
Examination failed, GDB will be halted. Polling again in 3100ms
Examination failed, GDB will be halted. Polling again in 6300ms
Original Attachment has been moved to: imx6sxea-com-tsn.dts.zip
Original Attachment has been moved to: imx6.cfg.zip
Original Attachment has been moved to: imx6sxea-com.dtsi.zip
