RTCS how to support VLAN Tag
xuwillie
I meet a problem.I use K65 with MQX and RTCS.I need  support VLAN Tag to connect switch.
I do this:
#define RTCSCFG_ENABLE_8021Q 1
but it doesn't work.Computer can ping K65,but can't open the web page on K65.
If something wrong i did?
soledad
Please check the below link and let me know if this helps:
MQX4.00 support VLAN?
Sol
xuwillie
This link says that "#define RTCSCFG_LINKOPT_8021Q_PRIO 1" ,but i use MQX 4.4.0 witch  have no "RTCSCFG_LINKOPT_8021Q_PRIO",but only " RTCSCFG_ENABLE_8021Q".
danielchen
Yes, in MQX 4.2  it is RTCSCFG_ENABLE_8021Q. By default, RTCS does not send and receive Ethernet 802.1Q tags, Set this value to 1 to have RTCS send and receive Ethernet 802.1q (VLAN) tags.
Please see the RTCS user guider for more details
