Hi:
I am looking for a MCU-based solution to interface with LVDS or JESD204B (preferred as it uses less lines). I could find any until I see AFD4400. However the documentation, datasheet are protected. I wonder if this solution could be used? Has anyone with FPGA SoC tried this solution. I am totally new to FPGA but reluctant to go into it has very high starting and hidden costs, good technical supports are also not easy to find.
