MPC 5500 & 5600, LCD
mateuszolsztyn
Hi all,
im using mpc5643L microcontroller and i want to display something. Can i use to it graphical LCD from Nokia 3310 (pcd8544)? Is it possible? Or can You recommend me something else?
Thanks & Regards
Mateusz
Tags (4)
PetrS
This LCD uses simple SPI bus (/SCE, SCLK, DIN) and some general inputs pins to control the display. So it can be easily controlled by any MPC5xxx MCU, the MPC5643L for sure. Only the driver have to be written by you. But you can find many examples for Nokia 3310 LCD handling on the web, so you can easily tailor it to your MCU.
BR, Petr
PetrS
BR, Petr
mateuszolsztyn
Cool, thank You very much for help. :smileyhappy:
