The IMX6SXRM descibes the ENET1_RGMII_TXC signal as "Serial output Ethernet data. Only valid during TX_EN assertion." in Table 24-1. What is the correct description of the ENET1_RGMII_TXC signal?
Vadim Aleynikov
Solved! Go to Solution.
Hi Vadim
this is clock which is clocking rgmii data, depicted on
Figure 54. RGMII Transmit Signal Timing Diagram Original i.MX6SX Datasheet
http://cache.freescale.com/files/32bit/doc/data_sheet/IMX6SXCEC.pdf
Hi Vadim
