Problems with directives (ifndef and ifdef)
norbertoj
I have some problems with infndef. I have a struct type 'structX'  in a header, and I have another declaration in another header. I put a ifndef with USE_TO_TEST for the structX of the second header. USE_TO_TEST  is defined. I compiled and I got the next Error "Conflict type of 'structX'. I don't know why there is a conflict in the second header; the ifndef is not TRUE.
Hello Norberto,
Which version of CW do you used ?
Could you please create one simple project,  then copy and paste your
structure file , send to me , i can check it on my side .
BRAlice
