vectors adding error by opencl on i.mx6d
zhengfudi
Hi all,
I am learning opencl on i.mx6d, I wrote kernel code like this:
__kernel void helloworld ( __global uchar *input1,
__global uchar *input2,
__global uchar *output,
int width,
int height,
    int y = get_global_id (0);
    int x = get_global_id (1);
    int id = (y * width) + x;
    output[id] = input1[id];    // ok
    // output[id] = input2[id];    // ok
    // output[id] = input1[id] + input2[id];    // error
    // output[id] = 0x01;    // error
and host code like this:
#include <stdio.h>
#include <stdlib.h>
#include <assert.h>
#include "../include/CL/cl.h"
#define FSLCL_ERROR -1
#define FSLCL_SUCCESS CL_SUCCESS
#define MAX_SOURCE_SIZE (0x100000)
cl_mem buffer_input = NULL;
cl_mem buffer_input2 = NULL;
cl_mem buffer_output = NULL;
cl_kernel buffer_kernel = NULL;
size_t buffer_size = 0;
int buffer_width = 1024;
int buffer_height = 1024;
cl_platform_id platform_id;
cl_device_id device_id;
cl_context context;
cl_command_queue cq;
cl_program program;
cl_kernel kernel;
struct fsl_kernel_src_str
    char *src;
    long size;
typedef struct fsl_kernel_src_str fsl_kernel_src;
cl_int FSLCL_LoadKernelSource (char *filename, fsl_kernel_src *kernel)
    FILE *fp = NULL;
    fp = fopen (filename, "rb");
    if (fp == NULL)
        printf ("\nFailed to open: %s\n", filename);
        return FSLCL_ERROR;
    fseek (fp, 0, SEEK_END);
    kernel->size = ftell (fp);
    rewind (fp);
    kernel->src = (char *) malloc (10 + sizeof (char) * kernel->size);
    if (! kernel->src)
        printf ("\nError Allocating memory to load CL program");
        return FSLCL_ERROR;
    kernel->size = fread (kernel->src, 1, MAX_SOURCE_SIZE, fp);
    if (kernel->size < 1) {
        printf("read file(%s) fail, ret=%d.\n", filename, kernel->size);
    kernel->src[kernel->size] = '\0';
    fclose (fp);
    fp = NULL;
    printf("close fp.\n");
    return FSLCL_SUCCESS;
int main (int argc, char **argv)
    int dimension = 2;
    size_t global[2] = {buffer_width, buffer_height};
    size_t local[2] = {4, 16};
    int size_2d = buffer_width * buffer_height;
    cl_int ret;
    cl_int platforms;
    char **data;
    char **data2;
    char **data0;
    int i, j;
    data0= (char **) malloc (buffer_width * sizeof (char *));
    data = (char **) malloc (buffer_width * sizeof (char *));
    data2 = (char **) malloc (buffer_width * sizeof (char *));
    if(NULL == data0 || NULL == data || NULL == data2) {
        printf("malloc1 err: %x, %x, %x\n", data0, data, data2);
        return -1;
    for (i = 0; i < buffer_width; i++)
        data0[i] = (char *) malloc (buffer_height * sizeof (char));
        data[i] = (char *) malloc (buffer_height * sizeof (char));
        data2[i] = (char *) malloc (buffer_height * sizeof (char));
        if(NULL == data0[i] || NULL == data[i] || NULL == data2[i]) {
            printf("malloc2 err in i%d: %x, %x, %x\n", i, data0[i], data[i], data2[i]);
            return -1;
        for (j = 0; j < buffer_height; j++)
            data0[i][j] = 0;
            data[i][j] = 0;
            data2[i][j] = 0;
    ret = clGetPlatformIDs (1, &platform_id, &platforms );
    printf("clGetPlatformIDs ret = %d\n", ret);
    assert (ret == CL_SUCCESS);
    cl_int devices;
    ret = clGetDeviceIDs (platform_id,CL_DEVICE_TYPE_GPU,1,&device_id, &devices);
    cl_context_properties properties[] = {CL_CONTEXT_PLATFORM, (cl_context_properties)platform_id, 0};
    context = clCreateContext(properties, devices, &device_id, NULL,NULL,&ret);
    printf("clCreateContext ret =%d\n", ret);
    cq = clCreateCommandQueue(context, device_id, 0, &ret);
    printf("clCreateCommandQueue ret =%d\n", ret);
    fsl_kernel_src app_kernel;
    ret = FSLCL_LoadKernelSource ((char *)"helloworld.cl", &app_kernel);
    printf("FSLCL_LoadKernelSource ret =%d\n", ret);
    // Submit the source code of the kernel to OpenCL
    program = clCreateProgramWithSource (context, 1, (const char **)&app_kernel.src, 0,&ret);
    printf("clCreateProgramWithSource ret =%d\n", ret);
    // and compile it (after this we could extract the compiled version)
    if (ret == CL_SUCCESS)
        ret = clBuildProgram (program, 1, device_id, NULL, NULL, NULL);
    if (ret < 0)
        printf ("Failed\n");
        printf ("\nReturn: %d\n", ret);
        clGetProgramBuildInfo(program, device_id, CL_PROGRAM_BUILD_LOG, app_kernel.size, app_kernel.src, NULL);
        printf ("\n%s", app_kernel.src);
    assert(ret == CL_SUCCESS);
    buffer_input = clCreateBuffer (context, CL_MEM_READ_ONLY, size_2d, NULL, &ret);
    printf("clCreateBuffer for input ret =%d\n", ret);
    buffer_input2 = clCreateBuffer (context, CL_MEM_READ_ONLY, size_2d, NULL, &ret);
    printf("clCreateBuffer for input2 ret =%d\n", ret);
    buffer_output = clCreateBuffer (context, CL_MEM_WRITE_ONLY , size_2d, NULL, &ret);
    // get a handle and map parameters for the kernel
    kernel = clCreateKernel(program, "helloworld", &ret);
    printf("clCreateKernel ret =%d\n", ret);
    usleep(100*1000);
    clSetKernelArg (kernel, 0, sizeof(cl_mem), &buffer_input);
    clSetKernelArg (kernel, 1, sizeof(cl_mem), &buffer_input2);
    clSetKernelArg (kernel, 2, sizeof(cl_mem), &buffer_output);
    clSetKernelArg (kernel, 3, sizeof(int), &buffer_width);
    clSetKernelArg (kernel, 4, sizeof(int), &buffer_height);
            data0[i][j] = rand () % 10;
            data[i][j] = rand () % 10;
    ret = clEnqueueWriteBuffer (cq, buffer_input, CL_TRUE, 0, size_2d, data0, 0, NULL, NULL);
    printf("clEnqueueWriteBuffer input1 ret =%d\n", ret);
    ret = clEnqueueWriteBuffer (cq, buffer_input2, CL_TRUE, 0, size_2d, data, 0, NULL, NULL);
    printf("clEnqueueWriteBuffer input2 ret =%d\n", ret);
    ret = clEnqueueNDRangeKernel(cq, kernel, dimension, NULL, &global, &local, 0, NULL, NULL);
    printf("clEnqueueNDRangeKernel ret =%d\n", ret);
    clFinish(cq);
    ret = clEnqueueReadBuffer(cq, buffer_output, CL_TRUE, 0, size_2d, data2, 0, NULL, NULL);
    printf("clEnqueueReadBuffer ret =%d\n", ret);
    printf ("\nResult:\n");
            // printf ("\n%d , %d -- %d", data0[i][j], data[i][j], data2[i][j]);
            printf("%d, ", data2[i][j]);
    printf ("\n");
    clFlush( cq);
    clFinish(cq);
    clReleaseMemObject (buffer_input);
    clReleaseMemObject (buffer_input2);
    clReleaseMemObject (buffer_output);
    clReleaseContext(context);
    clReleaseKernel(kernel);
    clReleaseProgram(program);
    clReleaseCommandQueue(cq);
        free(data0[i]);
        free(data[i]);
        free(data2[i]);
    free(data0);
    free(data);
    free(data2);
    return 0;
Question:
If the computing method in kernel code is "output[id] = input1[id];" or "output[id] = input2[id];", the whole program works well.
But, if the computing method in kernel code changed to "output[id] = input1[id]+input2[id];" or "output[id] = 0x01;", the program runs with an error output: segmentation fault. I have corfirmed that the line leads to this is "printf("%d, ", data2[i][j]);" in host code, but i am not sure what is the true cause. I will really appreciate it if someone can help me.
Hi zheng
please look at hello world example on
OpenCL Hello World | NXP Community
https://community.freescale.com/servlet/JiveServlet/previewBody/100694-102-1-15669/White%20Paper%20o...
