I am using the SDK 1.8 and build an image. I include dev-pkgs and tools-dev in the Yocto build image. I try to compile and a *.cc file and I get the following error:
make[2]: Warning: File `lib/CMakeFiles/gnuradio-l3mod.dir/flags.make' has modification time 3.9e+0
2 s in the future
Scanning dependencies of target gnuradio-l3mod
make[2]: warning: Clock skew detected. Your build may be incomplete.
2 s in the future
[ 16%] Building CXX object lib/CMakeFiles/gnuradio-l3mod.dir/l3_impl.cc.o
In file included from /usr/include/boost/config.hpp:40:0,
from /usr/include/boost/smart_ptr/shared_ptr.hpp:17,
from /usr/include/boost/shared_ptr.hpp:17,
from /usr/include/gnuradio/types.h:27,
from /usr/include/gnuradio/runtime_types.h:27,
from /usr/include/gnuradio/io_signature.h:27,
from /home/root/gr-l3mod/lib/l3_impl.cc:25:
/usr/include/boost/config/select_stdlib_config.hpp:18:21: fatal error: cstddef: No such file or di
rectory
# include <cstddef>
compilation terminated.
make[2]: *** [lib/CMakeFiles/gnuradio-l3mod.dir/l3_impl.cc.o] Error 1
make[1]: *** [lib/CMakeFiles/gnuradio-l3mod.dir/all] Error 2
make: *** [all] Error 2
root@b4860:~/gr-l3mod/build#
I looks like the standard include path for the compiler is not being set right. How can I fix this?
C-
Use SDK toolchain for your software compiling. Use the following command sequence:
(http://www.freescale.com/infocenter/index.jsp?topic=%2FQORIQSDK%2F3069706.html).
Build and install the standalone toolchain with Yocto:
$ source ./fsl-setup-poky -m <machine>
$ bitbake fsl-toolchain
$ cd build_<machine>_release/tmp/deploy/sdk
$ ./fsl-networking-eglibc-<host-system>-<core>-toolchain-<release>.sh
Note: The default installation path for standalone toolchain is /opt/. The install folder can be specified during the installation procedure.
Command sequence example for the LS1043A SDK 2.0.
sudo chmod 777 /opt/fsl-qoriq/2.0/environment-setup-ppce6500-fsl-linux
Each time you wish to use the SDK in a new shell session, you need to source the environment setup script e.g.
$ source /opt/fsl-qoriq/2.0/environment-setup-aarch64-fsl-linux
source /opt/fsl-qoriq/2.0/environment-setup-ppce6500-fsl-linux
Check result of "source" command. Use "echo $PATH" command. The "source" command should add path to gcc compiler.
You should see similar message:
echo $PATH
bash: /opt/fsl-qoriq/1.9/sysroots/x86_64-fslsdk-linux/usr/bin:/opt/fsl-qoriq/1.9/sysroots/x86_64-fslsdk-linux/usr/bin/powerpc-fsl-linux-gnuspe:
CC test.c -o test.elf
Use similar command sequence for the b4860 and SDK 1.8.
Pavel Chubakov
My first error I posted was running on the target platform (b4860qds-64b). Your response is related to the development platform that Yocto is building on. How do I get the right toolchain on the target platform so that the cstddef is found correctly?
