Hi all,
in the documentation of the LS1 the EVT9_B pin is listed in the group of Programmable Interrupt Controller. As part of the EPU (Event Processing Unit) could this also selected as interrupt source but it don't work.
Is there a code sample available for the initial configuration of the EPU?
We realy appreciate your response.
Best regards and thank you in advance,
Christian
