Hi all, Am having an issue whereby I cant seem to get Kinetis Design Studio to focus the current project correctly thereby making it so I cant use PE at all, anyone know of a fix for this ?
Hi Matthew,
If I understand your problem correctly: You need to select the project in the Project Explorer view:
I hope this helps,
Erich
Hello Metthew,
In order to help you solve this question , could you please describe the issue clearly ?
Which chip ? What the project ? What about the error ? Please take screenshots about
the issue .
Alice
