XIANGYANG LIU
one very strange problem:(:(
Discussion created by XIANGYANG LIU on Jun 15, 2008
Latest reply on Jun 16, 2008 by CrasyCat
Dear All
     I just modified my code to simplest form, and the compiler still gives error message, here is my code:
#include <stdio.h>
main(){
    short n1,n2,i,j,k;
    n2 = 16;
    for (k=16; k > 1; k = k/2 )
        n1 = n2;    n2 = n2/2;
        for (j=0; j < n2; j++)
            for (i=j; i < 16; i = i + n1)
    printf("END\n");
Very simple code, but compiler always gives such error:
scc -g -ge -env "C:\Program Files\Freescale\CodeWarrior for StarCore 3.1\StarCore_Support\compiler"  -be  -arch sc3400 -sc -mod -Og -O3 -Xlnk "-w" -Xlnk "-n" -o "C:\Documents and Settings\victorlxy\My Documents\FreeScale Projecs\test\project.eld" "test_Data\C_for_SC_Simulator\ObjectCode\main.obj"
Link Error   : ERROR: Non-zero return status from "C:\Program Files\Freescale\CodeWarrior for StarCore 3.1\StarCore_Support\compiler\bin\icode.exe".
Tool = SCC | Error ID = 1027
Project: test.mcp, Target: C for SC Simulator
Error   : "prototype_be.obj", line -1: Error: Bad call to linear solver (build_ud_linear_combi)
 - Context: <main'_main>
Tool = ICODE | Error ID = 3401
Link Error   : link exit status = 2
but the stranger problem here is that I changed one variable n2 to an integer such as 2, then it will work fine...how strange it is...:smileysad:
that is I changed my code to the following
#include <stdio.h>
main(){
    short n1,n2,i,j,k;
    n2 = 16;
        n1 = n2;    n2 = n2/2;
        for (j=0; j < 2; j++)
    printf("END\n");
just changed the n2 to "2" in the red "2" place
then this code will run with no such above error message....
anyone knows how to deal with this problem ,  is this the complier problem ?? since I just could not find any error in my code
Best Regards
thank you all in advance
