HDMI audio output drift at 44,1 KHz
guerinyoann
I use a custom board with a i.MX6Q.
I play a video with audio of 20 minutes. At begin, the audio and the video are OK.
But, at 15 minutes, the audio lags behind the video of 645 ms. The output audio is HDMI and the sampling frequency is 44,1 KHz.
If I change the sampling frequence from 44,1 KHz to 48 KHz, I haven't this problem.
If I use the output AUD5 of AUDMUX and a sampling frequency of 44,1 KHz , I haven't this problem.
I don't understand this problem. Could you explain me it?
jimmychan
could you tell me which bsp are you using?
