HI,QIANG
We use IMX6Q+ADV7393 for CVBS OUPUT in a project.
We use L3.14.52_1.1.0_GA + L3.14.52_1.1.0_GA_bt656_output_patch, But the video is bad.
ADV7393 8bit YCRCB输入,CVBS OUTPUT.
MX6QDL_PAD_DI0_DISP_CLK__IPU1_DI0_DISP_CLK 0x7010
MX6QDL_PAD_DISP0_DAT8__IPU1_DISP0_DATA08 0x7010
MX6QDL_PAD_DISP0_DAT9__IPU1_DISP0_DATA09 0x7010
MX6QDL_PAD_DISP0_DAT10__IPU1_DISP0_DATA10 0x7010
MX6QDL_PAD_DISP0_DAT11__IPU1_DISP0_DATA11 0x7010
MX6QDL_PAD_DISP0_DAT12__IPU1_DISP0_DATA12 0x7010
MX6QDL_PAD_DISP0_DAT13__IPU1_DISP0_DATA13 0x7010
MX6QDL_PAD_DISP0_DAT14__IPU1_DISP0_DATA14 0x7010
MX6QDL_PAD_DISP0_DAT15__IPU1_DISP0_DATA15 0x7010
I CHECK it care fully dan discused with QIANG ,He gived some suggestions,but not good.
Log is below:
Starting Telephony daemon
Starting Linux NFC daemon
Starting OProfileUI server
Running local boot scripts (/etc/rc.local).
24M_clk: disagrees about version of symbol module_layout
insmod: ERROR: could not insert module /home/root/24M_clk.ko: Invalid module format
Stopping Bootlog daemon: bootlogd.
Poky (Yocto Project Reference Distro) 1.6.2 imx6qdlsolo /dev/ttymxc1
imx6qdlsolo login: root
root@:~# cd /media/mmcblk2p1/
root@:/media/mmcblk2p1# insmod cvbs_mxcfb_adv739x.ko
root@:/media/mmcblk2p1# cd /sys/class/graphics/fb
-sh: cd: /sys/class/graphics/fb: No such file or directory
root@:/media/mmcblk2p1# cd /sys/class/graphics/fb0
root@:/sys/class/graphics/fb0#
root@:/sys/class/graphics/fb0# echo 1>blank
在启动后,insmod 7393KO,在echo 1>blank后, 不播放视频。
用示波器测试 cpu侧的波形。
发现CPU侧就有波形产生,就是这些不明来历的波形,才造成了图像的失真。
DATA8:
data9:
请问:在我们echo1>blank,怎么会产生这样的波形?我们的设置可能哪里出了问题 ?
When the display is blanking, there should be no data output, you need check your hardware whether there is other noise?
Please attach your kernel boot up log.
HI,Qiang,This is our log.
THKS
U-Boot 2014.04-gc6b4b58-dirty (Jul 21 2016 - 17:09:47)
CPU: Freescale i.MX6D rev1.5 at 792 MHz
CPU: Temperature 41 C, calibration data: 0x5844dc7d
Reset cause: POR
Board: MX6-SabreSD
I2C: ready
DRAM: 2 GiB
MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 2
No panel detected: default to Hannstar-XGA
Display: Hannstar-XGA (1024x768)
In: serial
Out: serial
Err: serial
Found PFUZE100 deviceid=10,revid=21
mmc1 is current device
Net: FEC [PRIME]
Warning: failed to set MAC address
Normal Boot
Hit any key to stop autoboot: 0
reading boot.scr
** Unable to read file boot.scr **
reading zImage
6049560 bytes read in 651 ms (8.9 MiB/s)
Booting from mmc ...
reading imx6q-sabresd-bt656.dtb
43062 bytes read in 33 ms (1.2 MiB/s)
Kernel image @ 0x12000000 [ 0x000000 - 0x5c4f18 ]
## Flattened Device Tree blob at 18000000
Booting using the fdt blob at 0x18000000
Using Device Tree in place at 18000000, end 1800d835
switch to ldo_bypass mode!
Starting kernel ...
Booting Linux on physical CPU 0x0
Linux version 3.14.52 (zc@dellubuntu) (gcc version 4.6.2 20110630 (prerelease) (Freescale MAD -- Linaro 2011.07 -- Built at 2011/08/10 09:20) ) #23 SMP PREEMPT Tue Aug 9 09:18:18 CST 2016
CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
Machine model: Freescale i.MX6 Quad SABRE Smart Device Board
cma: CMA: reserved 320 MiB at 6a000000
Memory policy: Data cache writealloc
PERCPU: Embedded 8 pages/cpu @ee72e000 s8320 r8192 d16256 u32768
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 520720
Kernel command line: console=ttymxc1,115200 root=/dev/mmcblk2p2 rootwait rw video=mxcfb0:dev=bt656,BT656-PAL,if=BT656,fbpix=RGB24 video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 262144 (order: 8, 1048576 bytes)
Inode-cache hash table entries: 131072 (order: 7, 524288 bytes)
Memory: 1739308K/2097152K available (7458K kernel code, 460K rwdata, 2588K rodata, 384K init, 433K bss, 357844K reserved, 270336K highmem)
Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
vmalloc : 0xf0000000 - 0xff000000 ( 240 MB)
lowmem : 0x80000000 - 0xef800000 (1784 MB)
pkmap : 0x7fe00000 - 0x80000000 ( 2 MB)
modules : 0x7f000000 - 0x7fe00000 ( 14 MB)
.text : 0x80008000 - 0x809d7c48 (10048 kB)
.init : 0x809d8000 - 0x80a38080 ( 385 kB)
.data : 0x80a3a000 - 0x80aad080 ( 461 kB)
.bss : 0x80aad08c - 0x80b196d4 ( 434 kB)
SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=2
NR_IRQS:16 nr_irqs:16 16
L310 cache controller enabled
l2x0: 16 ways, CACHE_ID 0x410000c7, AUX_CTRL 0x32070000, Cache size: 1024 kB
Switching to timer-based delay loop
sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 1431655765682ns
Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
Mount-cache hash table entries: 4096 (order: 2, 16384 bytes)
Mountpoint-cache hash table entries: 4096 (order: 2, 16384 bytes)
CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
Setting up static identity map for 0x10715e00 - 0x10715e58
CPU1: Booted secondary processor
CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
Brought up 2 CPUs
SMP: Total of 2 processors activated (12.00 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
pinctrl core: initialized pinctrl subsystem
regulator-dummy: no parameters
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor ladder
cpuidle: using governor menu
CPU identified as i.MX6Q, silicon rev 1.5
Use WDOG2 as reset source
syscon 20c8000.anatop: regmap [mem 0x020c8000-0x020c8fff] registered
vdd1p1: 800 <--> 1375 mV at 1100 mV
vdd3p0: 2625 <--> 3400 mV at 3000 mV
vdd2p5: 2000 <--> 2750 mV at 2400 mV
vddarm: 725 <--> 1450 mV
vddpu: 725 <--> 1450 mV
vddsoc: 725 <--> 1450 mV
syscon 20e0000.iomuxc-gpr: regmap [mem 0x020e0000-0x020e0037] registered
syscon 21bc000.ocotp-ctrl: regmap [mem 0x021bc000-0x021bffff] registered
hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
hw-breakpoint: maximum watchpoint size is 4 bytes.
imx6q-pinctrl 20e0000.iomuxc: Invalid fsl,pins property in node /soc/aips-bus@02000000/iomuxc@020e0000/imx6qdl-sabresd/ipu1grp
imx6q-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
bio: create slab <bio-0> at 0
mxs-dma 110000.dma-apbh: initialized
usb_otg_vbus: 5000 mV
usb_h1_vbus: 5000 mV
wm8962-supply: no parameters
mipi_dsi_pwr_on: no parameters
sensor-supply: 3300 mV
i2c-core: driver [max17135] using legacy suspend method
i2c-core: driver [max17135] using legacy resume method
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
usbphy_nop1.12 supply vcc not found, using dummy regulator
usbphy_nop2.13 supply vcc not found, using dummy regulator
i2c i2c-0: IMX I2C adapter registered
i2c i2c-1: IMX I2C adapter registered
i2c i2c-2: IMX I2C adapter registered
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
imx-ipuv3 2400000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
imx-ipuv3 2800000.ipu: IPU DMFC NORMAL mode: 1(0~1), 5B(4,5), 5F(6,7)
mxc_mipi_csi2 21dc000.mipi_csi: i.MX MIPI CSI2 driver probed
mxc_mipi_csi2 21dc000.mipi_csi: i.MX MIPI CSI2 dphy version is 0x3130302a
MIPI CSI2 driver module loaded
Advanced Linux Sound Architecture Driver Initialized.
Bluetooth: Core ver 2.18
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
Bluetooth: L2CAP socket layer initialized
Bluetooth: SCO socket layer initialized
cfg80211: Calling CRDA to update world regulatory domain
Switched to clocksource mxc_timer1
TCP established hash table entries: 16384 (order: 4, 65536 bytes)
TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
TCP: Hash tables configured (established 16384 bind 16384)
TCP: reno registered
UDP hash table entries: 1024 (order: 3, 32768 bytes)
UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
RPC: Registered named UNIX socket transport module.
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
RPC: Registered tcp NFSv4.1 backchannel transport module.
hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
imx rpmsg driver is registered.
imx_busfreq busfreq.16: DDR medium rate not supported.
Bus freq driver module loaded
futex hash table entries: 512 (order: 3, 32768 bytes)
bounce pool size: 64 pages
VFS: Disk quotas dquot_6.5.2
Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
NFS: Registering the id_resolver key type
Key type id_resolver registered
Key type id_legacy registered
jffs2: version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
fuse init (API version 7.22)
msgmni has been set to 3509
io scheduler noop registered
imx-weim 21b8000.weim: Driver registered.
backlight.27 supply power not found, using dummy regulator
mxc_mipi_dsi 21e0000.mipi: i.MX MIPI DSI driver probed
MIPI DSI driver module loaded
bt656 plat_data->ipu_id 00
bt656 plat_data->disp_id 00
mxc_sdc_fb fb.25: registered mxc display driver bt656
Console: switching to colour frame buffer device 90x36
adv739x_probe--6
reg addr 0x80,value 0x11
reg addr 0x82,value 0xc3
reg addr 0x0,value 0x1c
imx-sdma 20ec000.sdma: no iram assigned, using external mem
imx-sdma 20ec000.sdma: no event needs to be remapped
imx-sdma 20ec000.sdma: loaded firmware 3.2
imx-sdma 20ec000.sdma: initialized
pfuze100-regulator 1-0008: Full layer: 2, Metal layer: 1
pfuze100-regulator 1-0008: FAB: 0, FIN: 0
pfuze100-regulator 1-0008: pfuze100 found.
SW1AB: 300 <--> 1875 mV at 1150 mV
SW1C: 300 <--> 1875 mV at 1175 mV
SW2: 800 <--> 3300 mV at 3000 mV
SW3A: 400 <--> 1975 mV at 1500 mV
SW3B: 400 <--> 1975 mV at 1500 mV
SW4: 800 <--> 1975 mV at 1800 mV
SWBST: 5000 <--> 5150 mV at 5000 mV
VSNVS: 1000 <--> 3000 mV at 3000 mV
VREFDDR: 750 mV
VGEN1: 1200 mV
VGEN2: 1500 mV
VGEN3: 1800 mV
VGEN4: 3300 mV
VGEN5: 2500 mV
VGEN6: 2800 mV
Serial: IMX driver
2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 58, base_baud = 5000000) is a IMX
21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 59, base_baud = 5000000) is a IMX
console [ttymxc1] enabled
serial: Freescale lpuart driver
imx sema4 driver is registered.
[drm] Initialized drm 1.1.0 20060810
[drm] Initialized vivante 1.0.0 20120216 on minor 0
brd: module loaded
loop: module loaded
ahci-imx 2200000.sata: fsl,transmit-level-mV not specified, using 00000024
ahci-imx 2200000.sata: fsl,transmit-boost-mdB not specified, using 00000480
ahci-imx 2200000.sata: fsl,transmit-atten-16ths not specified, using 00002000
ahci-imx 2200000.sata: fsl,receive-eq-mdB not specified, using 05000000
ahci-imx 2200000.sata: failed to reset phy: -110
ahci-imx: probe of 2200000.sata failed with error -110
m25p80 spi0.0: unrecognized JEDEC id ffffff
spi_imx 2008000.ecspi: probed
CAN device driver interface
2188000.ethernet supply phy not found, using dummy regulator
pps pps0: new PPS source ptp0
fec 2188000.ethernet (unregistered net_device): Invalid MAC address: 00:00:00:00:00:00
fec 2188000.ethernet (unregistered net_device): Using random MAC address: 6e:7e:a0:f1:13:77
libphy: fec_enet_mii_bus: probed
fec 2188000.ethernet eth0: registered PHC device 0
ehci-mxc: Freescale On-Chip EHCI Host driver
usbcore: registered new interface driver usb_ehset_test
2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
ci_hdrc ci_hdrc.1: doesn't support gadget
ci_hdrc ci_hdrc.1: EHCI Host Controller
ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 1
ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 1 port detected
mousedev: PS/2 mouse device common for all mice
i2c-core: driver [isl29023] using legacy suspend method
i2c-core: driver [isl29023] using legacy resume method
snvs_rtc 20cc034.snvs-rtc-lp: can't get snvs-rtc clock
snvs_rtc 20cc034.snvs-rtc-lp: rtc core: registered 20cc034.snvs-rtc-lp as rtc0
i2c /dev entries driver
IR NEC protocol handler initialized
IR RC5(x) protocol handler initialized
IR RC6 protocol handler initialized
IR JVC protocol handler initialized
IR Sony protocol handler initialized
IR RC5 (streamzap) protocol handler initialized
IR SANYO protocol handler initialized
IR MCE Keyboard/mouse protocol handler initialized
mxc_v4l2_output v4l2_out.30: V4L2 device registered as video16
mxc_v4l2_output v4l2_out.30: V4L2 device registered as video17
mag3110 2-000e: check mag3110 chip ID
mag3110 2-000e: read chip ID 0xfffffffb is not equal to 0xc4!
mag3110: probe of 2-000e failed with error -22
i2c-core: driver [mag3110] using legacy suspend method
i2c-core: driver [mag3110] using legacy resume method
mma8451 0-001c: read chip ID 0x1 is not equal to 0x1a or 0x2a!
mma8451: probe of 0-001c failed with error -22
imx2-wdt 20c0000.wdog: IMX2+ Watchdog Timer enabled. timeout=60s (nowayout=0)
Bluetooth: HCI UART driver ver 2.2
Bluetooth: HCI H4 protocol initialized
Bluetooth: HCI BCSP protocol initialized
Bluetooth: HCIATH3K protocol initialized
usbcore: registered new interface driver bcm203x
usbcore: registered new interface driver btusb
usbcore: registered new interface driver ath3k
sdhci: Secure Digital Host Controller Interface driver
sdhci: Copyright(c) Pierre Ossman
sdhci-pltfm: SDHCI platform and OF driver helper
mmc1: no vqmmc regulator found
mmc1: no vmmc regulator found
mmc1: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
mmc2: no vqmmc regulator found
mmc2: no vmmc regulator found
mmc2: SDHCI controller on 2198000.usdhc [2198000.usdhc] using ADMA
mmc3: no vqmmc regulator found
mmc3: no vmmc regulator found
mmc2: new SDHC card at address eaa2
mmcblk2: mmc2:eaa2 SD04G 3.69 GiB
mmc3: SDHCI controller on 219c000.usdhc [219c000.usdhc] using ADMA
mmcblk2: p1 p2
Galcore version 5.0.11.33433
mxc_vdoa 21e4000.vdoa: i.MX Video Data Order Adapter(VDOA) driver probed
mxc_vpu 2040000.vpu: VPU initialized
caam 2100000.caam: Instantiated RNG4 SH0
caam 2100000.caam: Instantiated RNG4 SH1
caam 2100000.caam: device ID = 0x0a160100 (Era 4)
caam 2100000.caam: job rings = 2, qi = 0
caam algorithms registered in /proc/crypto
caam_jr 2101000.jr0: registering rng-caam
platform caam_sm: blkkey_ex: 4 keystore units available
platform caam_sm: 64-bit clear key:
platform caam_sm: [0000] 00 01 02 03 04 0f 06 07
platform caam_sm: 64-bit black key:
platform caam_sm: [0000] 6e 87 17 80 e1 fc a9 c6
platform caam_sm: [0008] bc 96 a3 ed d6 a0 a2 5d
platform caam_sm: 128-bit clear key:
platform caam_sm: [0008] 08 09 0a 0b 0c 0d 0e 0f
platform caam_sm: 128-bit black key:
platform caam_sm: [0000] e8 ef 38 a4 45 ec a9 64
platform caam_sm: [0008] 5a b7 29 98 54 4f 8a 05
platform caam_sm: 192-bit clear key:
platform caam_sm: [0016] 10 11 12 13 14 15 16 17
platform caam_sm: 192-bit black key:
platform caam_sm: [0000] c6 88 43 fb 97 3a a3 4a
platform caam_sm: [0008] 54 1e a0 49 f6 85 5f 88
platform caam_sm: [0016] b3 c8 4c 23 38 1c 4a 40
platform caam_sm: [0024] 5f 81 18 ec 8b 4a 03 9b
platform caam_sm: 256-bit clear key:
platform caam_sm: [0024] 18 19 1a 1b 1c 1d 1e 1f
platform caam_sm: 256-bit black key:
platform caam_sm: [0000] 08 96 df 6d ad 80 c7 1f
platform caam_sm: [0008] 30 25 49 b0 06 8d fe 5e
platform caam_sm: [0016] 20 97 06 f1 64 40 ec ed
platform caam_sm: [0024] 7c ad b7 4f d7 ee 35 a5
platform caam_sm: 64-bit unwritten blob:
platform caam_sm: [0000] 00 00 00 00 00 00 00 00
platform caam_sm: [0008] 00 00 00 00 00 00 00 00
platform caam_sm: [0016] 00 00 00 00 00 00 00 00
platform caam_sm: [0024] 00 00 00 00 00 00 00 00
platform caam_sm: [0032] 00 00 00 00 00 00 00 00
platform caam_sm: [0040] 00 00 00 00 00 00 00 00
platform caam_sm: [0048] 00 00 00 00 00 00 00 00
platform caam_sm: [0056] 00 00 00 00 00 00 00 00
platform caam_sm: [0064] 00 00 00 00 00 00 00 00
platform caam_sm: [0072] 00 00 00 00 00 00 00 00
platform caam_sm: [0080] 00 00 00 00 00 00 00 00
platform caam_sm: [0088] 00 00 00 00 00 00 00 00
platform caam_sm: 128-bit unwritten blob:
platform caam_sm: 196-bit unwritten blob:
platform caam_sm: 256-bit unwritten blob:
platform caam_sm: 64-bit black key in blob:
platform caam_sm: [0000] 70 72 d1 c9 3e 35 83 6c
platform caam_sm: [0008] d0 4e 38 fd 31 4b 75 11
platform caam_sm: [0016] 1c 9d 2f ee 50 91 74 cf
platform caam_sm: [0024] 9b 18 a1 3a 51 9d 5b d5
platform caam_sm: [0032] e9 2a 1c 40 15 c9 2c 6b
platform caam_sm: [0040] b1 f7 64 df 08 a3 ea 14
platform caam_sm: [0048] 04 e8 40 5e 68 c0 66 25
platform caam_sm: 128-bit black key in blob:
platform caam_sm: [0000] 41 38 2a 68 0e 6e 89 44
platform caam_sm: [0008] 3d 9d a9 ba 54 2f 2f a3
platform caam_sm: [0016] 54 2d ce b7 f8 29 3b b5
platform caam_sm: [0024] c6 5f cd bd a4 32 c5 22
platform caam_sm: [0032] 25 81 5a 66 7d ac 59 1c
platform caam_sm: [0040] 64 67 fa 83 f9 0b 73 71
platform caam_sm: [0048] 9a 82 c5 12 98 79 32 e5
platform caam_sm: [0056] b1 1f 31 d4 84 55 91 02
platform caam_sm: 192-bit black key in blob:
platform caam_sm: [0000] b1 3d 26 57 1e 56 f3 a2
platform caam_sm: [0008] 58 5f 40 ac 8a ee 30 de
platform caam_sm: [0016] 26 35 b4 bd 2a 4d 73 22
platform caam_sm: [0024] c5 ab 9e d9 bb ab 50 09
platform caam_sm: [0032] b8 69 ea 2e 3c e6 d6 ff
platform caam_sm: [0040] 29 2b 62 69 86 2c ba 30
platform caam_sm: [0048] e6 d0 bb f7 5b ba 06 77
platform caam_sm: [0056] f2 55 2b 23 f6 25 3f 2c
platform caam_sm: [0064] f6 8d d9 e3 e1 a1 ab 6e
platform caam_sm: 256-bit black key in blob:
platform caam_sm: [0000] 08 b4 83 c6 4a 1e 5d d8
platform caam_sm: [0008] c5 58 a8 91 36 3c 59 9a
platform caam_sm: [0016] 9c c9 18 8a 15 e5 8a 28
platform caam_sm: [0024] 3b 85 27 ca 00 38 26 80
platform caam_sm: [0032] e0 83 11 74 7a b5 f9 74
platform caam_sm: [0040] 75 47 46 44 33 54 a7 bc
platform caam_sm: [0048] 8f 3a 19 9d de c7 4c 69
platform caam_sm: [0056] cb aa 7d 10 73 24 53 80
platform caam_sm: [0064] 01 75 13 2c 44 90 0b db
platform caam_sm: [0072] 70 78 6f 9c b6 68 74 8c
platform caam_sm: restored 64-bit black key:
platform caam_sm: [0000] fb d0 15 88 06 5b 75 19
platform caam_sm: [0008] 8a 60 73 6a 35 da 42 e0
platform caam_sm: restored 128-bit black key:
platform caam_sm: restored 192-bit black key:
platform caam_sm: [0016] 0f 97 a2 e5 a4 fb 8b 79
platform caam_sm: [0024] 8e 81 92 cb bf c7 d9 c9
platform caam_sm: restored 256-bit black key:
snvs-secvio 20cc000.caam-snvs: can't get snvs clock
snvs-secvio 20cc000.caam-snvs: violation handlers armed - non-secure state
usbcore: registered new interface driver usbhid
usbhid: USB HID core driver
wm8962 0-001a: Failed to read ID register
wm8962: probe of 0-001a failed with error -5
fsl-asrc 2034000.asrc: driver registered
fsl-hdmi-dai hdmi_audio.3: failed to probe. Load HDMI-video first.
fsl-hdmi-dai: probe of hdmi_audio.3 failed with error -12
imx-wm8962 sound.23: failed to find codec platform device
imx-wm8962: probe of sound.23 failed with error -22
imx-audio-hdmi sound-hdmi.24: initialize HDMI-audio failed. load HDMI-video first!
NET: Registered protocol family 26
TCP: cubic registered
NET: Registered protocol family 10
sit: IPv6 over IPv4 tunneling driver
can: controller area network core (rev 20120528 abi 9)
NET: Registered protocol family 29
can: raw protocol (rev 20120528)
can: broadcast manager protocol (rev 20120528 t)
can: netlink gateway (rev 20130117) max_hops=1
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM ver 1.11
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bluetooth: BNEP socket layer initialized
Bluetooth: HIDP (Human Interface Emulation) ver 1.2
Bluetooth: HIDP socket layer initialized
8021q: 802.1Q VLAN Support v1.8
Key type dns_resolver registered
SWBST: disabling
SW4: disabling
wm8962-supply: disabling
usb_otg_vbus: disabling
regulator-dummy: disabling
imx mcc test is registered.
input: gpio-keys.22 as /devices/soc0/gpio-keys.22/input/input0
snvs_rtc 20cc034.snvs-rtc-lp: setting system clock to 1970-01-01 00:00:02 UTC (2)
ALSA device list:
No soundcards found.
kjournald starting. Commit interval 5 seconds
EXT3-fs (mmcblk2p2): using internal journal
EXT3-fs (mmcblk2p2): recovery complete
EXT3-fs (mmcblk2p2): mounted filesystem with ordered data mode
VFS: Mounted root (ext3 filesystem) on device 179:2.
devtmpfs: mounted
Freeing unused kernel memory: 384K (809d8000 - 80a38000)
INIT: version 2.88 booting
Starting udev
udevd[248]: starting version 182
FAT-fs (mmcblk2p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Starting Bootlog daemon: bootlogd: cannot allocate pseudo tty: No such file or directory
bootlogd.
random: dd urandom read with 88 bits of entropy available
ALSA: Restoring mixer settings...
net.ipv4.conf.default.rp_filter = 1
net.ipv4.conf.all.rp_filter = 1
/usr/sbin/alsactl: load_state:1729: No soundcards found...
Mon Jan 5 19:24:00 UTC 2015
INIT: Entering runlevel: 5
Configuring network interfaces... fec 2188000.ethernet eth0: Freescale FEC PHY driver [Generic PHY] (mii_bus:phy_addr=2188000.ethernet:00, irq=-1)
IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
udhcpc (v1.22.1) started
Sending discover...
libphy: 2188000.ethernet:00 - Link is Up - 1000/Half
IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Sending discover...
Sending discover...
random: nonblocking pool is initialized
No lease, failing
Starting Xserver
Starting system message bus: dbus.
Starting Connection Manager
Starting Dropbear SSH server: dropbear.
Starting rpcbind daemon...done.
creating NFS state directory: done
starting statd: done
Starting advanced power management daemon: No APM support in kernel
(failed.)
NFS daemon support not enabled in kernel
Starting syslogd/klogd: done
* Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon
...done.
imx6qdlsolo login:
There is error in your IOMUX setting for the IPU pins:
