cant reboot successfully when When some packets sent to P4080ds
shanfeifei
Hi.
I ran lpm-ipfwd(configure fm2-gb3 and fm1-gb2 as share mac) on P4080ds board,When some packets sent to P4080ds,I typed "reboot".But it didnt reboot successfully.
If there were no packets sent to P4080ds,I reboot the board successfully.
So how to solve the problem?
The log is :
root@p4080ds:~# reboot
Broadcast message from root@p4080ds (ttyS0) (Sat Jul 30 15:40:42 2016):
The system is going down for reboot NOW!
INIT: Sending processes the TERM signal
INIT: Stopping Dropbear SSH server: stopped /usr/sbin/dropbear (pid 2239)
dropbear.
Stopping system message bus: dbus.
Stopping network benchmark server: netserverstopped /usr/sbin/netserver (pid 2266)
stopping mountd: done
stopping nfsd: nfsd: last server has exited, flushing export cache
.socks: : Network is unreachable
done
Stopping system log daemon...0
Stopping kernel log daemon...0
Stopping tcf-agent: socks: : Network is unreachable
OK
Stopping internet superserver: xinetd.
stopping statd: done
Shutting down MySQL..socks: : Network is unreachable
.[  OK  ]
Stopping crond: OK
Stopping rpcbind daemon...
done.
Deconfiguring network interfaces... done.
Sending all processes the TERM signal...
lpm-ipfwd:handleFatalSignal Number is 15
Received TERM or STOP signal...  shutting down...
Receiver SIGINT, SIGHUP or SIGTERM, Shutting down
select: Interrupted system call
ha_spawn_task:/root/HA/EXE/ha_ipmi_script.sh
******Killimg CMGR childs*****
sh: line 0: kill: (2797) - No such process
plat_type is 6
This palt type is 6
Do Not Support lighting LED
ifconfig eth0 down finish
ifconfig fm1-gb2 down finish
close_fsl_usdpaa_fd close OK
worker_free(worker not first) finish
Sending all processes the KILL signal...
Unmounting remote filesystems...
Deactivating swap...
Unmounting local filesystems...
Rebooting... INFO: rcu_sched self-detected stall on CPU { 0}  (t=5251 jiffies g=1215 c=1214 q=8721)
CPU: 0 PID: 2511 Comm: lpm_ipfwd_app Tainted: G           O 3.12.19-rt30-QorIQ-SDK-V1.6+gc29fe1a #3
INFO: rcu_sched detected stalls on CPUs/tasks: { 0} (detected by 1, t=5252 jiffies, g=1215, c=1214, q=8721)
Task dump for CPU 0:
lpm_ipfwd_app   R running      0  2511      1 0x00002006
Call Trace:
[c6231a90] [c009d9f0] rcu_check_callbacks+0x320/0x6e0 (unreliable)
[c6231af0] [c003b190] update_process_times+0x40/0x70
[c6231b10] [c00868d8] tick_sched_timer+0x68/0xb0
[c6231b40] [c0053594] __run_hrtimer.isra.28+0x54/0xe0
[c6231b60] [c0054244] hrtimer_interrupt+0x164/0x430
[c6231be0] [c0009e48] timer_interrupt+0x1b8/0x1f0
[c6231c10] [c0010274] ret_from_except+0x0/0x18
--- Exception: 901 at usdpaa_release+0xbc0/0x1010
    LR = usdpaa_release+0x4bc/0x1010
[c6231d70] [c00f5bdc] __fput+0x9c/0x210
[c6231d90] [c004bbf4] task_work_run+0xc4/0x110
[c6231db0] [c002eea0] do_exit+0x280/0x8d0
[c6231e00] [c0030398] do_group_exit+0x48/0xb0
[c6231e20] [c003eaf8] get_signal_to_deliver+0x168/0x4e0
[c6231e70] [c0007ab0] do_signal+0x40/0x210
[c6231f30] [c0007d98] do_notify_resume+0x68/0x80
[c6231f40] [c0010840] do_user_signal+0x74/0xc4
--- Exception: c00 at 0xfef1638
    LR = 0x100052d4
Call Trace:
[c6231a40] [c0006f50] show_stack+0x40/0x150 (unreliable)
[c6231a80] [c067014c] dump_stack+0x78/0xa0
    LR = 0x100052d4
INFO: rcu_sched self-detected stall on CPU { 0}  (t=21006 jiffies g=1215 c=1214 q=8724)
INFO: rcu_sched detected stalls on CPUs/tasks: { 0} (detected by 1, t=21007 jiffies, g=1215, c=1214, q=8724)
Call Trace:
    LR = 0x100052d4
Call Trace:
    LR = 0x100052d4
INFO: rcu_sched self-detected stall on CPU { 0}  (t=36761 jiffies g=1215 c=1214 q=8725)
INFO: rcu_sched detected stalls on CPUs/tasks: { 0} (detected by 1, t=36762 jiffies, g=1215, c=1214, q=8725)
Call Trace:
    LR = 0x100052d4
shanfeifei
Today this problem happened again,When too many packets sent to P4080ds,I typed "reboot",the system failed to reboot system,the log as follows:
Cannot recover FQ 0x13b, it is scheduled on channel 0x64stopping mountd: done
stopping nfsd: done
Stopping tcf-agent:
INFO: rcu_sched detected stalls on CPUs/tasks: { 7} (detected by 4, t=5253 jiffies, g=7178, c=7177, q=3144)
Task dump for CPU 7:
lpm_ipfwd_app R running 0 2534 1 0x00002006
Call Trace:
[e9ff5a90] [c19a1180] 0xc19a1180 (unreliable)
INFO: rcu_sched detected stalls on CPUs/tasks: { 7} (detected by 4, t=21008 jiffies, g=7178, c=7177, q=4289)
Call Trace:
the command of lpm-ipfwd is : "lpm_ipfwd_app 7 -c usdpaa_config_p4_serdes_0xe_ok.xml -p usdpaa_policy_hash_ipv4_arp_coarse_classify_ok.xml -d 0x10000000 -b 1600:1600:1600"
