Problems with OV5640 MIPI
shree97
Hello all,
I am trying to interface the OV5640MIPI camera with our custom board running on i-MX6 solo.In our schematics below signals are coming to MIPI connector from processor:
1)MIPI_CSI_CLK0_N
2)MIPI_CSI_CLK0_P
3)MIPI_CSI_D0_N
4)MIPI_CSI_D0_P
5)MIPI_CSI_D1_N
6)MIPI_CSI_D1_P
7)CAM_PWR_EN(GPIO) from pad CSI0_DAT18
8)CAM_PWDN_3V3 (GPIO) from pad CSI0_DAT14
9)CAM_RESET_3V3(GPIO) from pad CSI0_DAT15
After that I referred many device tree files but I didn't find this pin muxing in any DTSI file which are using MIPI camera.Instead of that I found below pin-muxing in every dtsi file which are using MIPI camera:
pinctrl_ipu1_2: ipu1grp-2 { /* parallel camera */
            fsl,pins = <
                MX6QDL_PAD_CSI0_DAT12__IPU1_CSI0_DATA12    0x80000000
                MX6QDL_PAD_CSI0_DAT13__IPU1_CSI0_DATA13    0x80000000
                MX6QDL_PAD_CSI0_DAT14__IPU1_CSI0_DATA14    0x80000000
                MX6QDL_PAD_CSI0_DAT15__IPU1_CSI0_DATA15    0x80000000
                MX6QDL_PAD_CSI0_DAT16__IPU1_CSI0_DATA16    0x80000000
                MX6QDL_PAD_CSI0_DAT17__IPU1_CSI0_DATA17    0x80000000
                MX6QDL_PAD_CSI0_DAT18__IPU1_CSI0_DATA18    0x80000000
                MX6QDL_PAD_CSI0_DAT19__IPU1_CSI0_DATA19    0x80000000
                MX6QDL_PAD_CSI0_DATA_EN__IPU1_CSI0_DATA_EN 0x80000000
                MX6QDL_PAD_CSI0_PIXCLK__IPU1_CSI0_PIXCLK   0x80000000
                MX6QDL_PAD_CSI0_MCLK__IPU1_CSI0_HSYNC      0x80000000
                MX6QDL_PAD_CSI0_VSYNC__IPU1_CSI0_VSYNC     0x80000000
So my question is are this Pin muxing is necessary for MIPI camera to work ? In our schematics this pads are ued for other functionalities like UART,I2S,GPIO etc, So is it causing problem.
By referring all these DTSI files I modified my DTSI file as below:
            fsl,pins = <
&i2c3 {
    clock-frequency = <100000>;
    pinctrl-names = "default";
    pinctrl-0 = <&pinctrl_i2c3>;
    status = "okay";
    ft5x06_ts@38 {
        compatible = "ft5x06-ts";
        reg = <0x38>;
                interrupts-extended = GPIRQ_I2C3_J7;
        wakeup-gpios = GP_I2C3_J7;
    ov5640_mipi: ov5640_mipi@3c { /* i2c2 driver */
        compatible = "ovti,ov5640_mipi";
        reg = <0x3c>;
        //pinctrl-names = "default";
        pinctrl-0 = <&pinctrl_ipu1_2>;
        clocks = <&clks 201>;
        clock-names = "csi_mclk";
        DOVDD-supply = <&wlan_en_reg>; /* 1.8v */
        AVDD-supply = <&vgen3_reg>;  /* 2.8v, rev C board is VGEN3
                        rev B board is VGEN5 */
        DVDD-supply = <&vgen2_reg>;  /* 1.5v*/
        pwn-gpios = <&gpio6 00 1>;   /* active low: SD1_CLK */
        rst-gpios = <&gpio6 01 0>;   /* active high: SD1_DAT2 */
        csi_id = <1>;
        mclk = <24000000>;
        mclk_source = <0>;
&i2c3 {
    status = "okay";
    ft5x06_ts@38 {
        reg = <0x38>;
        reg = <0x3c>;
        csi_id = <1>;
        mclk = <24000000>;
        mclk_source = <0>;
&mipi_csi {
    status = "okay";
    ipu_id = <0>;
    csi_id = <1>;
    v_channel = <0>;
    lanes = <2>;
but its giving below errors after inserting ov5640_camera_mipi.ko
ov5640_read_reg:write reg error:reg=300a
camera ov5640_mipi is not found
Kindly help regarding this issue.
Thanks & Regards,
Shrikant
Tags (2)
Hi shree97
MIPI_CSI_ are analog signals and not muxed with other signals.
not found error may be related to i2c miscommunication, for example on
below example camera is connected to i2c2:
linux-2.6-imx.git - Freescale i.MX Linux Tree
So it makes sense to check i2c communication with oscilloscope.
shree97
Hi igorpadykov,
I modified the DTSi file as below :
v4l2_cap_0 {
        compatible = "fsl,imx6q-v4l2-capture";
        ipu_id = <0>;
        csi_id = <0>;
        mclk_source = <0>;
        status = "okay";
    v4l2_cap_1 {
        ipu_id = <0>;
        csi_id = <1>;
        mclk_source = <0>;
        status = "okay";
    v4l2_out {
        compatible = "fsl,mxc_v4l2_output";
        status = "okay";
pinctrl_i2c3: i2c3grp {
            fsl,pins = <
                MX6QDL_PAD_EIM_D18__I2C3_SDA        0x4001b8b1
                MX6QDL_PAD_EIM_D17__I2C3_SCL        0x4001b8b1
                MX6QDL_PAD_EIM_D21__GPIO3_IO21         0x1b0b0   // For Touchscreen Reset
            #define GPIRQ_I2C3_J7    <&gpio4 20 IRQ_TYPE_EDGE_FALLING>
            #define GP_I2C3_J7 <&gpio4 20 GPIO_ACTIVE_LOW>
                MX6QDL_PAD_DI0_PIN4__GPIO4_IO20       0x1b0b0  //For Touch Interrupt
&i2c3 {
    status = "okay";
    ft5x06_ts@38 {
        reg = <0x38>;
        reg = <0x3c>;
        //pinctrl-0 = <&pinctrl_ipu1_2>;
        csi_id = <1>;
        mclk = <24000000>;
        mclk_source = <0>;
&mipi_csi {
    status = "okay";
    ipu_id = <0>;
    csi_id = <1>;
    v_channel = <0>;
    lanes = <2>;
after that I load the below modules and the response is as below:
root@imx6qdlsolo:~# insmod v4l2-int-device.ko
root@imx6qdlsolo:~# insmod ov5640_camera_int.ko
root@imx6qdlsolo:~# insmod ov5640_camera_mipi.ko
camera ov5640_mipi is found
root@imx6qdlsolo:~# insmod adv7180_tvin.ko
root@imx6qdlsolo:~# insmod ipu_prp_enc.ko
root@imx6qdlsolo:~# insmod ipu_fg_overlay_sdc.ko
root@imx6qdlsolo:~# insmod ipu_still.ko
root@imx6qdlsolo:~# insmod ipu_csi_enc.ko
root@imx6qdlsolo:~# insmod ipu_bg_overlay_sdc.ko
root@imx6qdlsolo:~# insmod mxc_v4l2_capture.ko
root@imx6qdlsolo:~# ERROR: v4l2 capture: slave not found!
root@imx6qdlsolo:~# i2cdetect -y 2
     0  1  2  3  4  5  6  7  8  9  a  b  c  d  e  f
00:          -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
20: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
30: -- -- -- -- -- -- -- -- UU -- -- -- UU -- -- --
40: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
50: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
Dmesg output related to camera:
write_reg: set register 0x00 to 0x00
set_mode: changed mode to 0x00
Also I checked the Waveforms using logic analyzer.
Also I tried with the drivers as buit-in modules but I got the same errors.
kindly give you suggestions regarding this issue.
Thanks & Regards,
Shrikant
bandarulavanya
Contributor V
Hi Shee97,
have you tried capturing using mxc_v4l2_capture.out . then what it is giving and can you disable ov5640 dvp related camera in menuconfig.
Lavanya
shree97
Hi Lavanya,
The output of ./mxc_v4l2_capture.out is as below:
root@imx6qdlsolo:/unit_tests# ./mxc_v4l2_capture.out
in_width = 176, in_height = 144ERROR: v4l2 capture: slave not found!
out_width = 176, out_height = 144
top = 0, left = 0
Unable to open /dev/video0
Unable to create y frame recording file
I am unable to debug this error "ERROR: v4l2 capture: slave not found!"
Thanks & Regards,
Shrikant
bandarulavanya
Contributor V
Hi Shrikant,
can you try probing pwd and rst pins status using oscilloscope. where the options for mxc_v4l2_capture.out
Thanks & regards,
Lavanya
bandarulavanya
Contributor V
Hi Shrikant,
Thanks & regards,
Lavanya
bandarulavanya
Contributor V
Hi Shee97,
Lavanya
bandarulavanya
Contributor V
Hi shree97 ,
It is looking like I2C Problem can you check once by probing I2C lines.
Lavanya
shree97
Hi Lavanya,
v4l2_cap_0 {
        ipu_id = <0>;
        csi_id = <0>;
        mclk_source = <0>;
        status = "okay";
    v4l2_cap_1 {
        ipu_id = <0>;
        csi_id = <1>;
        mclk_source = <0>;
        status = "okay";
    v4l2_out {
        status = "okay";
            fsl,pins = <
&i2c3 {
    status = "okay";
    ft5x06_ts@38 {
        reg = <0x38>;
        reg = <0x3c>;
        csi_id = <1>;
        mclk = <24000000>;
        mclk_source = <0>;
&mipi_csi {
    status = "okay";
    ipu_id = <0>;
    csi_id = <1>;
    v_channel = <0>;
    lanes = <2>;
kindly help regarding this issue.
Thanks & Regards,
Shrikant
bandarulavanya
Contributor V
Hi shree97 ,
can you try once making your modules as static drivers and check whether same error is coming or not
Thanks & regards,
Lavanya
shree97
Hi Lavanya,
I tried the drivers as built in modules but still I am getting the same error as below:
Thanks & Regards,
Shrikant
