How can I mask all Interrupts on MK21FN1M0VMC12
brentgreenwald
I see the ARM has a non-maskable interrupt (NMI). Is there an easy way to mask all maskable interrupts, like a single flag or bit?
Labels (2)
BlackNight
Hi Brent,
yes, the 'I' bit in the PRIMASK ARM core register. Below how to enable/disable all maskable interrupts:
#define DisableInterrupts()          __asm volatile("cpsid i")
#define EnableInterrrupts()        __asm volatile("cpsie i")
I hope this helps,
Erich
BlackNight
Hi Brent,
I hope this helps,
Erich
