Trying to match the BGU6101 to 50 ohms at 110MHz. I can get the input match ok but then it moves S22 outside the Smith Chart. Can't seem to find any application circuits for this part.
Doug
You can use the application note which is made for the BGU6102
http://www.nxp.com/documents/application_note/AN11090.pdf
Andrei
