Source code for the NHS3100 demonstration firmware
bobbyfaller
Where can I find the source code for the NHS3100 demonstration firmware?
driesmoors
A download of the SDK is now made available via this link: Temperature logger|NXP - check the "Software & Tools" tab.
Best,
Dries.
driesmoors
Providing the full SDK together with example and demo code on the public NXP website is currently a work in progress. For now, all documentation, SDK, example code and demo applications are accessible through DocStore. More info about that can be found here: https://nxp.box.com/v/UMNHS3xxxDocStore
Apart from that, I can also offer you two email addresses as contact point: you can request technical information via nhs-support@nxp.com​ (or, even better, via your local FAE). Business opportunities and use case discussions can be started via nhs-info@nxp.com.
I hope you have a little patience, we're working hard to simplify the delivery of the code and documentation. Until then, DocStore is the resource point to turn to.
Greetings,
Dries.
