I tested the CAN peripheral in MPC5567 at 2Mbps baud rate, its working fine. Is it reliable? Is it creates any problem over a period of time?
MPC5567's FlexCAN module is designed according to CAN Specification version 2.0B, ISO Standard 11898 with max bitrate of 1Mbit/s. So it can work for you but this setting is not complaint with the standard.
BR, Petr
Hi petr,
Thanks for your response.
I tested it by setting 2Mbps baud rate with short length cables, its working.
But After testing with 30mtr cable. its not working.
This is for your information.
