Ethernet Registers
Ethernet Registers
saida
Ethernet Registers:
Hi I.mx6 community
Ethernet Registers are not accessible in my i.mx6 dual lite processor
how to enable these registers
thanks in advance
jimmychan
what bsp are you using?
saida
hi
its working, i am working on lwip stack implementation
1. MAC address is stored in FUSE MAP registers at address of registers are 0x021bc620 and 630 but when i am reading through DS5 debugger and in u-boot its showing zero only, even if MAC_LOCK is 0.
how can i find MAC of my i.mx6 duallite core ?
2. i am trying to run http server example application from IMX6SDK with Static IP option but its not running when i trying to access a web page
3. can any one give the solution to my problem or any ref doc.
4. you can send working code of httpserver so that i will try it
5. how can i achieve full implementation lwip stack for all applications
thank you and regards
saida
qinghuazhu
Can you describe the detail. How do you access the register and what the error is.
