Hi everyone,
I'm using Kinetis SDK 3.2.0 and am trying to write to register GPIOC_PTOR from a method in a source file other than main.c.
I believe I've prototyped it in the header properly.
The compiler is stating that GPIOC_PTOR is undeclared.
Any thoughts?
Hi Gregory,
if you include "fsl_device_registers.h", you should be able to access using:
GPIOC->PTOR = 0;
Marek
Hello Gregory,
Please include the header file which define GPIOC_PTOR ,
in the file which use the GPIOC_PTOR .
If still can not work , please send your project to me , i will check it on my side .
Hope it helps
Alice
