board freeze after indeterminate duration
wolfgangschneid
we have a custom i.mx6d board with android 5.0.2 implementation. after indeterminate duration the board freezes without any debug information on the serial console. we have done RAM calibration with the stress test tool and several memory tests without any error. mtest in bootloader and memtester in kernel with overclocking (580Mhz) an high temperature without error.
Labels (2)
weidong_sun
Hello Wolfgang,
    if you want to display booting logs on serical console, you should modify booting parameters of u-boot, add "selinux=disable" to environment of u-boot, then save it and reboot.
Weidong
wolfgangschneid
Hello Weidong,
we have already done this. see the copy from the console.
        enable_wait_mode=off console=ttymxc0,115200 init=/init video=mxcfb0:dev=ldb video=mxcfb1:off video=mxcfb2:off video=mxcfb3:off vmalloc=400M androidboot.selinux=disabled androidboot.console=ttymxc0 consoleblank=0 androidboot.hardware=freescale cma=384M vt.global_cursor_default=0 enable_wait_mode=off
we can't search for a mistake because the system tells us nothing !
do you have another idea ?
weidong_sun
Hello Wolfgang,
      Can android successfully boot? For example, android GUI is normally displayed on screen.
Weidong
