Hi! Greetings!
I am new to NXP community. I have started working on SA612A mixer. Since few days, I have been struggling in generating IF (KHz) output.
NXP SA612A pin description (A quick reference so that you don't have to refer to the datasheet):
Pin1,2: differential RF input pins
Pin3: Ground
Pin4,5: differential IF output pins
Pin6,7: LO differential input
Pin8: +5V
My circuit configuration and problem detail:
60KHz signal seems totally immersed in the noise, not a peak at all, what can be the reason? Tried with other frequencies as well.
Please share your views on this.
Sanket
