Doubts and Problem in Mpc5606b
akhilmalik
hi
1. Which pin(s) in MpC5606b is 5 volt output for connection with any other device.
2. In EMIOS the SAOC mode is not running on counter bus A even i've set BSL to 00.
please reply asap.
PetrS
  1. All GPIO pins in case device is powered by 5V.
  2. see attached example tested on TRK-MPC5606B
BR, Petr
akhilmalik
hi
i'm asking about the pin which provide 5V and sufficient current to run any sensor.
i hope u getting my point.
thanks
akhilmalik
hi
please reply a little soon.
its urgent.
thanks
